Mothers
- Has thanked: 9819 times
- Been thanked: 10144 times
Mothers
Most modern bikes don't have chrome or alloy to polish,so this recommendation is mainly for classics or retros such as Royal Oilfield.
For anything except chrome,this stuff knocks the likes of Autosol and Belgom Alu into a cocked hat,whatever that means.
https://www.ebay.co.uk/itm/255903291155
Not a great deal of time was spent rubbing the H1a today.
- Tricky
- Has thanked: 2564 times
- Been thanked: 2680 times
Re: Mothers
Cheers - I've been a lifelong solvol man and never heard of this before , but I know looking at your disgustingly shiny smokers it'll be decent stuff , so have just ordered a tub , mainly for all the lovely 1970s ally on the Laverda
Re: Mothers
It's well known in the US,but catching on here too. A lot less effort required than solvol and a noticeably better result.
- Has thanked: 1507 times
- Been thanked: 1409 times
Re: Mothers
It doesn't keep & turns into crap once it's opened, You'll likely end up throwing most of it away.
- Has thanked: 2550 times
- Been thanked: 6241 times
Re: Mothers
I use Peek, for no particular reason more than the fact i could find a big tin of that but not of autosol.
BTW, real, highly toxic, chrome is way better than the modern stuff IMO.
Re: Mothers
Maybe warmer where you are though?
Re: Mothers
True, but the heat doesn't affect other metal polishes & I probably have a half dozen kinds.
Re: Mothers
Any recommendations from your years of rubbing?
- Has thanked: 6375 times
- Been thanked: 4745 times
Re: Mothers
I've always had people recommend Solvol but, tbh, not been impressed when applied manually. Might work OK with a buffing wheel type thing but I always found the end result didn't justify the effort.
PS Every time I see this thread an image of Frank Zappa pops into my head.
- Has thanked: 7810 times
- Been thanked: 2526 times
Re: Mothers
Solvol requires a reasonable amount of effort, and also needs to be used regularly for best results. It's good for getting something already clean and shiny, properly clean and shiny. It also works best on old chrome and nickel plating, modern stuff doesn't get the same finish.Count Steer wrote: ↑Fri Oct 04, 2024 4:21 pm I've always had people recommend Solvol but, tbh, not been impressed when applied manually. Might work OK with a buffing wheel type thing but I always found the end result didn't justify the effort.
Re: Mothers
So what works best on alloy that may have got a little, erm, furry...like the bottom end of BMW forks?Rockburner wrote: ↑Fri Oct 04, 2024 4:24 pmSolvol requires a reasonable amount of effort, and also needs to be used regularly for best results. It's good for getting something already clean and shiny, properly clean and shiny. It also works best on old chrome and nickel plating, modern stuff doesn't get the same finish.Count Steer wrote: ↑Fri Oct 04, 2024 4:21 pm I've always had people recommend Solvol but, tbh, not been impressed when applied manually. Might work OK with a buffing wheel type thing but I always found the end result didn't justify the effort.
Re: Mothers
Replacement.Count Steer wrote: ↑Fri Oct 04, 2024 4:28 pmSo what works best on alloy that may have got a little, erm, furry...like the bottom end of BMW forks?Rockburner wrote: ↑Fri Oct 04, 2024 4:24 pmSolvol requires a reasonable amount of effort, and also needs to be used regularly for best results. It's good for getting something already clean and shiny, properly clean and shiny. It also works best on old chrome and nickel plating, modern stuff doesn't get the same finish.Count Steer wrote: ↑Fri Oct 04, 2024 4:21 pm I've always had people recommend Solvol but, tbh, not been impressed when applied manually. Might work OK with a buffing wheel type thing but I always found the end result didn't justify the effort.
Re: Mothers
I use minimal amounts on a folded blue paper shop towel. I have other stuff to use with power tools.Count Steer wrote: ↑Fri Oct 04, 2024 4:21 pm I've always had people recommend Solvol but, tbh, not been impressed when applied manually. Might work OK with a buffing wheel type thing but I always found the end result didn't justify the effort.
Re: Mothers
That's very inventive.Count Steer wrote: ↑Fri Oct 04, 2024 4:21 pm PS Every time I see this thread an image of Frank Zappa pops into my head.
- Has thanked: 85 times
- Been thanked: 687 times
Re: Mothers
My old z1000e used to get autosol'd to death. Shiniest outer float bowls known to man. Clutch/alternator/ pickups were also quite spangly
- Has thanked: 15938 times
- Been thanked: 10241 times
Re: Mothers
Presumably, the air gets to it. What if you made a cartouche to put on the surface, would that not solve the problem?
