Honda CBR650r sticky ignition barrel
- formula400
- Has thanked: 444 times
- Been thanked: 853 times
Right, the 2022 cbr650r has a sticky barrel, I out the key in and it’s hard to turn it.
It happened 4/5 months ago as well
I blasted it with WD-50 and it sorted it (a quick google today said dont do that)
My Honda face book group says to use graphite powder in the lock (but google also says do not as it’s outside and get clogged up when wet)
So what’s the score, how do I sort it???
Thanks
Thanks
CBR650r
- Has thanked: 532 times
- Been thanked: 7408 times
Re: Honda CBR650r sticky ignition barrel
Last week I did my font door key by rubbing it with a pencil, worked a threat.
You can get Graphite/PTFE sprays that will do the job.
- formula400
I’ve got some of this waiting at home
Or is what you have said better?
CBR650r
Should do the trick. It's an Ultion lock I Iubed with a pencilformula400 wrote: ↑Wed Oct 02, 2024 6:33 pm I’ve got some of this waiting at home
- Has thanked: 10094 times
- Been thanked: 6793 times
Motorcycle and Automotive All Metal Anti-Corrosion Spray 369ml
Brand: ACF-50
4.7 4.7 out of 5 stars 1,022 ratings
Amazon's
Choice
300+ bought in past month
£15.68 £15.68
Available with free Prime shipping from other sellers on Amazon.
Use on heads, cooling fins, throttle linkages, brake cables, battery terminals, voltage regulator, suspension, engine components, torsion, bars, fuel control units, fuse box, swing arm, relays and connectors, undercarriage, chain, ignition switch, security systems, FOBs and more!
ACF-50 can be sprayed on, wiped on with a rag, or professionally fogged for complete protection
Forms an active ultra-thin, clear film that
Brand: ACF-50
Amazon's
Choice
£15.68 £15.68
It might be ok, but I personally wouldn't put ACF-50 in a lock. It's super sticky stuff.
description actually says for ignition switches,KungFooBob wrote: ↑Wed Oct 02, 2024 7:48 pm It might be ok, but I personally wouldn't put ACF-50 in a lock. It's super sticky stuff.
Personally I think it’s the “fluid of the gods” fixes any rust lubrication issues ( not brakes mind)
Cheap easy fix to put a little on the key and put the key in the lock , u feel the difference nearly immediately and unlike w d 40 which evaporates this seeps into the nook and crannies and works for a long period
Plus u use so little you have the remainder for multitude of other tasks if needed
But hey hoe each to there own I suppose
- Has thanked: 1728 times
- Been thanked: 2045 times
I had trouble getting the key in and out of the RE 500 ignition earlier this year. Powder is no good once spray has been used. WD 40 didn't work.
Few drops of acf 50 on the key, insert, leave for 10 minutes and sorted. Slid in and out smoothly from that day forward. Turning the key was never issue.
- formula400
So, got home last night, no graphite powder, checked Amazon, delayed delivery
So I’ve ordered an AFC-50 as well, let’s see what comes first
CBR650r
- MrLongbeard
- Has thanked: 594 times
- Been thanked: 2375 times
Well it sure does make one appreciative of keyless ignition systems.
- formula400
Yeah fairMrLongbeard wrote: ↑Thu Oct 03, 2024 11:18 am Well it sure does make one appreciative of keyless ignition systems.
CBR650r
My Gasgas doesn't have any ignition, so nerr.MrLongbeard wrote: ↑Thu Oct 03, 2024 11:18 am Well it sure does make one appreciative of keyless ignition systems.
- Has thanked: 2530 times
- Been thanked: 6126 times
Strictly speaking the Bonnevile does, but you could hotwire it without even taking your gloves off
If you can start it, you can keep it. That's my motto
- Screwdriver
- Has thanked: 250 times
- Been thanked: 719 times
A key and barrel become difficult to use if they are worn, damaged or dirty. Flooding with any sort of lubricant is effectively masking the problem unless that also just happens to clean it from any foreign object or dirt.
The absolutely best way to fix any issue is to replace with new. Next best bet is to strip it down, examine for wear or damage, clean it and reassemble.
You might just get away wit a good, deep clean with something like isopropyl alcohol and then a very light oiling with something like 3in1. Chances are, once a lock becomes difficult, it's well on the way to becoming jammed. Imagine that at 4am on a cold wet, windy motorway.
Masking or disguising the issue is just delaying the inevitable.
Plato
Plato
- Has thanked: 6020 times
- Been thanked: 4995 times
ftfyMr. Dazzle wrote: ↑Sun Oct 06, 2024 9:13 am
If you can start it and keep it going further than the end of the road, you can keep it.
- formula400
So it’s had a cheeky squirt of AFC-50, key has been cleaned as it had a very small amount of dirt in the groves (minuscule) and seems to be working fine.
If it does happen again maybe I’ll have to look into getting the barrel cleaned if that’s possible.
But thanks for the help
CBR650r
- Has thanked: 474 times
- Been thanked: 1406 times
I was about to buy a new aftermarket barrel yesterday. £25 cheaper than the new keys i was quoted but then i thought, i still need under the seat so just paid for the new keys. Guy made me a third free and gave me them for £10 cheaper than first quoted. All three keys slide in and turn easier. More so when trying to get the steering lock on. Any change you have a worn key?
- formula400
Felix wrote: ↑Wed Oct 09, 2024 12:19 am I was about to buy a new aftermarket barrel yesterday. £25 cheaper than the new keys i was quoted but then i thought, i still need under the seat so just paid for the new keys. Guy made me a third free and gave me them for £10 cheaper than first quoted. All three keys slide in and turn easier. More so when trying to get the steering lock on. Any change you have a worn key?
No idea, I guess I’ll have to wait to see if it happens again and try a new key, unless they can look at it and see?
CBR650r
- Has thanked: 2218 times
- Been thanked: 1233 times
I WD40'd the door locks on one of the kids cars in desperation as was getting hard to unlock, costs me 2 new lock barrels!
It blew out all the remaining OEM lube and made the issue 10x worse.....
