Peaked helmets
Ditchfinder
Has thanked: 620 times
Been thanked: 692 times
Peaked helmets
Post by Ditchfinder »
Now I've got a winter shitbox for commuting on I've come up against low sun conditions on my way home on a few occasions.
Do peaked helmets solve this problem?
If so what's good and not too spendy for a country lane 20 min commute?
Speeds not likely to exceed 50mph so noise shouldn't be too bad, this bike is noisier than wind anyway 🙉
Been thanked: 7520 times
Re: Peaked helmets
Cheapest option is some black tape across the top of your existing visor.
Has thanked: 2402 times
Been thanked: 3625 times
Re: Peaked helmets
I'd suggest that a helmet with integral sun visor is probably your best bet.
https://www.sportsbikeshop.co.uk/motorc ... sun+visors
I have to say I've no experience with sun visor helmets, but have considered them from time to time.
Ditchfinder
Re: Peaked helmets
So double down on a visor and peak?
Something like this ?https://www.sportsbikeshop.co.uk/motorc ... rod/687896
Has thanked: 1829 times
Been thanked: 1469 times
Re: Peaked helmets
Sunglasses
Has thanked: 2903 times
Been thanked: 2052 times
Re: Peaked helmets
Ditchfinder wrote: Tue Sep 24, 2024 7:22 pm So double down on a visor and peak?
I was going to suggest something like the Airoh Commander etc. but - £55 for a bit of a commute for a while? Grab it with both hands. The peak's as well vented as any of the other pricier ones from the look of it.
Has thanked: 808 times
Been thanked: 4793 times
Re: Peaked helmets
mangocrazy wrote: Tue Sep 24, 2024 7:20 pm I'd suggest that a helmet with integral sun visor is probably your best bet.
I have Shoei one. I find it very agreeable. :thumbup: The internal visor works well and the Sena comms works well.
https://www.motolegends.com/motorcycle- ... i/gt-air-2
Yet to really figure the point of a peaked helmet, other than to complete the 'adventure' look.
Sadlonelygit
Has thanked: 85 times
Been thanked: 687 times
Re: Peaked helmets
Post by Sadlonelygit »
not so good when the wind gets up a bit!
integral sun visor is the answer ahbs
Has thanked: 599 times
Been thanked: 2428 times
Re: Peaked helmets
I'd not go for the internal visor, based solely on my opinion of a race dark visor not being dark enough, and it adding an extra layer to fog up, but electrical tape will work.
wheelnut
Has thanked: 904 times
Been thanked: 998 times
Re: Peaked helmets
Post by wheelnut »
Used a tour x4 for years - never had an issue with wind and found it useful for glare.
An internal sun visor would be useful but arai done do them.
Has thanked: 2549 times
Been thanked: 2285 times
Re: Peaked helmets
I have 2 helmets, one peaked, one not, otherwise almost identical.
The peak is occasionally useful for shading, but both have internal sun visors too. A strip of black tape is probably the best solution to really bad low sun glare.
The extra drag/wind of a peak is just not an issue. I don't feel any difference, even at motorway speeds.
Has thanked: 6374 times
Been thanked: 4745 times
Re: Peaked helmets
I was about to say Schuberth....then I saw the 'not too spendy'. :D
Has thanked: 7810 times
Been thanked: 2526 times
Re: Peaked helmets
Tape.
I used to use two visors (clear for heading north, dark for heading east), but the simplest answer is tape.
Has thanked: 6185 times
Been thanked: 5087 times
Re: Peaked helmets
KungFooBob wrote: Tue Sep 24, 2024 7:18 pm Cheapest option is some black tape across the top of your existing visor.
:thumbup:
Yup, ^ that
Get a lid that's comfy, stick tape on its visor. Lower edge just above eye level. Then you just need to dip your head slightly to block low sun. Gives you clear view ahead
Sunglasses darken everything.
Drop down inner visors aren't dark enough to block sunlight glare.
Ditchfinder
Re: Peaked helmets
Well I've ordered a peaky lid with internal visor and I will test it against my old lid with tape and report back (when it stops raining)
Re: Peaked helmets
Ditchfinder wrote: Thu Sep 26, 2024 12:06 am test it against my old lid with tape and report back
If it doesn't work for you, the answer is always 'more tape'
Has thanked: 16193 times
Been thanked: 3919 times
Re: Peaked helmets
Mr Moofo wrote: Tue Sep 24, 2024 7:44 pmSunglasses
I've never been keen on sunglasses in a lid. I have to wear glasses, but with a dark visor I can flip it up in a very shady area or one of the many tunnels, with sunglasses it feels like I'm a bit screwed on options if in an area that isn't 100% sunny all the time!
I did realise that I'll have to try the black tape thingy on my clear visor the other day - it had been a dull possibly rainy day when I headed down but sunny when I went back home. The clear visor was definitely not ideal !! I've never tried the tap, so need to do that next time I have the clear visor on just to lessen the blindingness!! LOL
Re: Peaked helmets
Has anyone ever made graduated tinted visors (dark at the top, like some windscreens)? Seems a bit of an obvs solution instead of slapping tape on things.
Re: Peaked helmets
Count Steer wrote: Thu Sep 26, 2024 8:49 am Has anyone ever made graduated tinted visors (dark at the top, like some windscreens)? Seems a bit of an obvs solution instead of slapping tape on things.
They used to be available, but:
- 'Newer' (25 years?) visor regs mandated minimum light transmission. So really dark visors are 'track use only', and graduated tint would fail too.
- You can apply the tape at the height appropriate for your eyes. Can't do that with a graduated tint
- Tint (as with sunglasses) won't block sunlight from your eyes. They will still react and reduce view through the untinted section.
Tape. I used cheapo beige masking tape, because I had some handy. Use expensive luxury plastic insulation tape if you must
Re: Peaked helmets
Horse wrote: Thu Sep 26, 2024 9:15 am
Kind of ironic that a a graduated visor with a heavy tint at the top is forbidden, so the work-around is to put a strip of opaque tape on. :lol: Hard to imagine why the first option is verboten but the second one isn't. :hmmm:
