Digital Tyre Pressure Gauge??
- Has thanked: 10113 times
- Been thanked: 6649 times
I've lost a few things recently. Bollox.
So now need a good digital tyre pressure gauge.
Waddya reckon?
Ta
Waddya reckon?
Ta
- Has thanked: 532 times
- Been thanked: 7217 times
Re: Digital Tyre Pressure Gauge??
I've got a cheap GT Moto one and a Halfrauds one.
They both read within 0.5 psi of each other.
The GT is easier to get on most valves, but I have to use the Halfrauds one on the GS due to the spoke/valve arrangement.
I don't think either cost more than a tenner.
- MrLongbeard
- Has thanked: 579 times
- Been thanked: 2288 times
Yeah. Can't get digital ones here. The only one I found was too small to read small pressures accurately.
- Has thanked: 308 times
- Been thanked: 553 times
I always end up breaking the digital ones really quickly so i have a draper 69924 analogue with a flexible hose (you can order it without the hose). the hose is really handy for bikes as it is nice and narrow onto the valve. It holds the pressure as well so when you take it off, you can see the pressure level.
If you really wanted a digital one then ignore me
All help appreciatedNordboy wrote: ↑Fri Sep 13, 2024 4:19 pm I always end up breaking the digital ones really quickly so i have a draper 69924 analogue with a flexible hose (you can order it without the hose). the hose is really handy for bikes as it is nice and narrow onto the valve. It holds the pressure as well so when you take it off, you can see the pressure level.
- Has thanked: 2632 times
- Been thanked: 1498 times
I just use a pencil gauge... the batteries always were flat in the digital ones whenever I needed it.
Or fit a tyre pressure monitoring kit...
- Pirahna
- Has thanked: 1772 times
- Been thanked: 1106 times
I use a Topeak digital guage. Topeak is a bicycle brand but it works on other tyres as well, does both presta and schrader valves.
I use one of these, most convenient
https://www.amazon.co.uk/gp/product/B0C ... UTF8&psc=1
Some digital ones are tested here
My trusty pencil gauge just failed. The screw fell out of the endThe Spin Doctor wrote: ↑Fri Sep 13, 2024 6:23 pm I just use a pencil gauge... the batteries always were flat in the digital ones whenever I needed it.
- DefTrap
- Has thanked: 2268 times
- Been thanked: 2086 times
- Has thanked: 2609 times
- Been thanked: 6012 times
I'd never used one of them until I borrowed my Dad's recently (he keeps one in their tow to quickly change the rear tyre pressure when on caravan holidays).
What is this magic? Bollox to pumping with your foot any more.
His one is self contained and charges from a ciggy lighter or bespoke power block, but all the usual suspects of battery power tool make em too I think.
I have a Halfords digital one which seems OK but isn't always easy to use on bike wheels. I also have a handful of the old displacement pencil types and they do last longer and have repeatable (in)accuracy over their life. Its the rotten rubber seal which can kill them. The most fragile gauges are the dial mechanical ones with aneroid style expanding chambers. Any miss handling throws them out of calibration in no time.
- Has thanked: 2318 times
- Been thanked: 3373 times
It's not digital (it's defiantly analogue), but it's the best tyre pressure gauge I've ever used.
https://www.ebay.co.uk/itm/266502168353
Yes I bought one of those RaceX ones, probably on your recommendation. Its very good so far but it won't always fit on small wheels such as scooters where discs and final drive cases or sprockets get in the way. I don't doubt that inside there is a delicate mechanism so I try to treat it with care and wouldn't leave it rattling around in a toolbox or car boot.mangocrazy wrote: ↑Sat Sep 14, 2024 12:45 pm It's not digital (it's defiantly analogue), but it's the best tyre pressure gauge I've ever used.
Yes, I treat it as you would a precision instrument. Take your point about using it on scooters or similar, I only use it on bike/car/van wheels.
I have the Makita inflator. It always let's air out when detaching. So need a gauge
