Page 1 of 2
Proper Blown Fuse
Posted: Mon Aug 26, 2024 10:40 am
Am going out later so thought I'd check the Suzuki will start. Struggled but couldn't quite tell as had headphones on.
So turned it on again and nothing.
Then I looked at main fuse. It's melted. Even melted a little hole in plastic casing
It's strange how all was OK 5 seconds earlier.
Now can I just clean it all up and put a new one in?
Or best to take it to a dealer to get properly checked out?
Ta
- 20240826_103521.jpg (701.46 KiB) Viewed 1668 times
- 20240826_103506.jpg (673.24 KiB) Viewed 1668 times
Re: Proper Blown Fuse
Posted: Mon Aug 26, 2024 11:04 am
by weeksy
Mmmm I don't like that. The obvious question is 'why'
What caused the fuse to go pear shaped.
Posted: Mon Aug 26, 2024 11:06 am
weeksy wrote: Mon Aug 26, 2024 11:04 am
Yup. Worried that I'll be stranded somewhere.
Have also asked on the GSXR forum to see if it's a known problem.
Posted: Mon Aug 26, 2024 11:10 am
by Mussels
I'd be looking for a big and broken cable, probably to the starter motor and burned.
Posted: Mon Aug 26, 2024 11:15 am
Also. After it was dead, I hooked it up to the battery charger.
Maybe this did the big damage after the fuse blew?
Posted: Mon Aug 26, 2024 11:17 am
by weeksy
Is it possible you fitted the charger the wrong way round? That's very much like a main fuse blown by fitted red to black
Posted: Mon Aug 26, 2024 12:03 pm
weeksy wrote: Mon Aug 26, 2024 11:17 am
No. It's got a tail bit.
Posted: Mon Aug 26, 2024 12:33 pm
by mangocrazy
That kind of damage is the universe's way of telling you to find out the root cause. Is that the main fuse? As Mussels says, I'd be checking out the big current devices like starter motor and alternator. Has the regulator/rectifier gone south?
Posted: Mon Aug 26, 2024 12:38 pm
by mangocrazy
If you fancy doing some initial troubleshooting, there are some good investigative guides here:
https://www.electrexworld.co.uk/acatalog/Technical.html
Posted: Mon Aug 26, 2024 1:24 pm
I'd want to know precisely what caused that amount of damage. Definitely not a case of sticking in a new fuse and heading off somewhere hoping for the best.
Posted: Mon Aug 26, 2024 1:55 pm
by DefTrap
I had something similar once. There was obvious corrosion, dirt and nastiness in and around where the main fuse had plugged in - possibly water ingress over years. Looked like it overheated before it blew the fuse.
So anyway I replacd the corroded and melted parts and the fuse, never happened again in the subsequent years I owned it.
Posted: Mon Aug 26, 2024 2:20 pm
Hmm. I don't like leccy and looks like it could be a few things. I could easily half fix it and it goes again
Gonna book it into shop.
Thanks all.
Posted: Mon Aug 26, 2024 2:27 pm
by mangocrazy
Keep us posted on the outcome - be interested to know what caused it.
Posted: Mon Aug 26, 2024 11:49 pm
by A_morti
Like they said, that's definitely not just a new fuse and ride into the sunset.
As voltage decreases, amps increase. Or something. Anyway, if the battery was very low, it could have caused things to get hot.
Or the starter or even engine might be seized.
Or dirty/ corroded/ loose terminals on a thick wire, probably with at least one end attached to the battery, starter solenoid, engine block, or starter.
Or bring it to the man to figure it out.
Posted: Tue Aug 27, 2024 10:19 am
by Wossname
It’s a common problem caused by cheap beer and too much sunshine.
Posted: Tue Aug 27, 2024 2:43 pm
It's booked in. They're busy, so September 24th
Posted: Tue Aug 27, 2024 2:52 pm
by weeksy
Fuck that, but a new bike until it's ready
Posted: Tue Aug 27, 2024 3:35 pm
Set it on fire, claim on the insurance.
I was obviously an electrical fault that started the fire.
Posted: Tue Aug 27, 2024 4:19 pm
weeksy wrote: Tue Aug 27, 2024 2:52 pm
I'll just ride the GasGas more. I can ride the GSXR all the next few months.
And at Portimao I'm hiring a tricked up GSXR1000 .
Posted: Tue Aug 27, 2024 5:48 pm
by ChrisW
Didn't you have to replace the main fuse a year or so ago? Do you know why it went then?
