Moth?
- Has thanked: 666 times
- Been thanked: 704 times
Moth?
I think it's moth?
I have a set of line plans, need someone to help me make sure I am reading them correctly, as digging up the power that feeds the village probably won't go down that well, as well as costing a fortune.
- Has thanked: 6188 times
- Been thanked: 5087 times
Re: Moth?
Decided to build that swimming pool? Or constructing an underground panic room bomb shelter?
Re: Moth?
I might be able to help, but my knowledge is telecoms rather than power, but the diagrams are similar.Wreckless Rat wrote: ↑Mon Sep 07, 2020 10:25 am I think it's moth?
There shouldn't be anything other than your own feed in your land, if someone else's power goes through your land there should be a Wayleave for it with your deeds.
If someone else's you can ask for it to be removed, whoever owns it has to reply within 28 days of your request - they don't have to move it in 28 days.
If it's your own power you have to pay for it to be moved and officially you can't move it your self.
Re: Moth?
I don't own the land, yet....Julian_Boolean wrote: ↑Mon Sep 07, 2020 10:58 amI might be able to help, but my knowledge is telecoms rather than power, but the diagrams are similar.Wreckless Rat wrote: ↑Mon Sep 07, 2020 10:25 am I think it's moth?
There shouldn't be anything other than your own feed in your land, if someone else's power goes through your land there should be a Wayleave for it with your deeds. If there is you can ask for it to be removed, whoever owns it has to reply within 28 days of your request - they don't have to move it in 28 days.
There is LV cable running there, under the foot path I think, but UKPN seem to have the apprentice on today who wasn't that helpful in being certain what the plan is telling me.
Re: Moth?
This is a bit worrying for me. Our elec power comes in under my next door neighbor's garden, about 18 inches under ground and is just an armoured cable in the soilJulian_Boolean wrote: ↑Mon Sep 07, 2020 10:58 amI might be able to help, but my knowledge is telecoms rather than power, but the diagrams are similar.Wreckless Rat wrote: ↑Mon Sep 07, 2020 10:25 am I think it's moth?
- moth
- Has thanked: 336 times
- Been thanked: 192 times
Re: Moth?
You have a PMWreckless Rat wrote: ↑Mon Sep 07, 2020 10:25 am I think it's moth?
Proud Tory scum since 1974.
Re: Moth?
It's nothing to worry about, if it's a shared feed it counts the same as if it was a soul feed to your neighbour, if your neighbour wants it moved the Leccy board will pay for it.
Re: Moth?
Mac n Cheese with some fried chicken?Julian_Boolean wrote: ↑Mon Sep 07, 2020 1:27 pm It's nothing to worry about, if it's a shared feed it counts the same as if it was a soul feed to your neighbour, if your neighbour wants it moved the Leccy board will pay for it.
- moth
Re: Moth?
Julian_Boolean wrote: ↑Mon Sep 07, 2020 1:27 pmIt's nothing to worry about, if it's a shared feed it counts the same as if it was a soul feed to your neighbour, if your neighbour wants it moved the Leccy board will pay for it.
I bet you the Leccy board (actually DNO) won't
- Has thanked: 1264 times
- Been thanked: 1188 times
Re: Moth?
I thought they worked to the same rules as BT, and if someone else's feed goes through your land you could ask to have it moved and it was the service provider who had to pay for moving it, anything else seems a bit unreasonable.moth wrote: ↑Mon Sep 07, 2020 2:43 pmJulian_Boolean wrote: ↑Mon Sep 07, 2020 1:27 pmIt's nothing to worry about, if it's a shared feed it counts the same as if it was a soul feed to your neighbour, if your neighbour wants it moved the Leccy board will pay for it.
