Vented jackets
Has thanked: 1829 times
Been thanked: 1469 times
Vented jackets
I am beginning to see the merit in one. I looked at the Knox stuff ( which had dial functionality as it could be used on an MTB. However the pricing is a tad ambiguous
What else is out there that works well and give good protection - CE 2 would be nice.
It would be good to have real world experiences :thumbup:
Re: Vented jackets
I've got a Furygan one, it's CE2, but it feels very thin when riding in it, definitely a cruising round in jacket rather than a going for it jacket.
Has thanked: 2402 times
Been thanked: 3625 times
Re: Vented jackets
My go-to jacket in the south of France is the Knox Urbane Pro jacket. It has close fitting CE2 armour and the outer shell is abrasion resistant so you can wear it on its own (or inside another jacket, if you wish). It copes better than I do in temperatures around or above 40 deg C. However it is pricey (£250 currently) although when Knox have a sale that price reduces quite a bit. But it is a dual-purpose piece of kit, so the pricing can be justified, I guess.
For UK use I have the Action Pro vest, which is designed to be worn under an outer abrasion resistant shell, and is a fair bit cheaper.
https://www.planet-knox.com/product/men ... mk3-black/
Has thanked: 599 times
Been thanked: 2428 times
Re: Vented jackets
Mr Moofo wrote: Sat Aug 17, 2024 8:27 pm What else is out there that works well and give good protection - CE 2 would be nice.
CE2 refers to the armour specification, the jacket will be A, AA or AAA rated.
I like my mesh jacket which I highly doubt would even pass the lowly A rating
Taff
Has thanked: 255 times
Been thanked: 885 times
Re: Vented jackets
Post by Taff »
I've got a triumph branded mesh jacket and I doubt that it would help much if I were sliding down the road at 70, but then my normal jacket would be unzipped if its that warm, so the ventilation is worth it on the 5 days a year it's warm enough.
Ian
Has thanked: 598 times
Been thanked: 319 times
Re: Vented jackets
Post by Ian »
I have one of these, https://www.bikersparadise.co.uk/Rida-T ... acket.html
I cant see any 'A' rating, I bought it probably 5+ years ago before that became a thing but all the impact areas are perforated leather and the mesh front seems robust. Its also snug fitting so the armour doesn't move around. It has a cotton mesh lining too which is nice.
With a Heatgear or similar top underneath it works well so long as you keep moving.
Re: Vented jackets
I've looked no e up and it has an A rating, I suspect that just means it might keep the armour in place.
Has thanked: 6186 times
Been thanked: 5087 times
Re: Vented jackets
Ian wrote: Sat Aug 17, 2024 10:46 pm I have one of these, https://www.bikersparadise.co.uk/Rida-T ... acket.html
Many companies are oddly reluctant to publish [crap] test results.
Has thanked: 15944 times
Been thanked: 10243 times
Re: Vented jackets
Had one for years. Its a Weiss and came with both a warm liner and a rain liner. Dunno where they are though, probably in the loft-of-plenty, as I only use it as a mesh jacket for hot days commuting. If I'm local i just ride in whatever i'm wearing and don't bother with it.
Has thanked: 2903 times
Been thanked: 2052 times
Re: Vented jackets
I've got a Furygan Mistral, which is ace for sort of 16+ degree stuff. It's my third & I recommend them.
More recently however I bought a Knox Urbane Pro & I've not used the Furygan since. Saying that, the riding days this year - albeit a bit sparse at times - have been on the warm side. If it is a bit towards the chilly side I just wear a long sleeve tee under it, or worst way, something over it.
Well worth the price.
Re: Vented jackets
That looks pretty good
Has thanked: 2635 times
Been thanked: 1523 times
Re: Vented jackets
Have a look at the MotoCAP site... not only do you get an independent (ie - not designed by the industry to pass almost anything) destruction test on garments but they test them for waterproofing and breathability too.
Having visited the lab and talked to Prof Chris Hurren extensively over the last few years, I do trust their results. Obviously since they are supported by the Aus / NZ governments, they focus on what's available locally and as they also have to 'secret shopper' and pay for the garments what's been tested is only a limited range, some of which aren't available in the UK. But it should give you a guide to what's comfortable AND protective to wear.
For example the RST Tractec Evo 4 Mesh gets a good rating for both safety and breathability at a mid-range price.
https://www.motocap.com.au/
Ian
Re: Vented jackets
Post by Ian »
It's good info but let's not get too carried away, a lamp post, bus stop or another vehicle is more likely to kill you than abrasions. Riding slower is much more likely to save your life.
Did I really just say that? I must be getting old.
Has thanked: 10261 times
Been thanked: 6885 times
Re: Vented jackets
Ian wrote: Tue Aug 20, 2024 12:04 pm It's good info but let's not get too carried away, a lamp post, bus stop or another vehicle is more likely to kill you than abrasions. Riding slower is much more likely to save your life.
Nah. If you ride twice as fast, you're only out for half the time.
Less time for any bad stuff.
YKIMS :obscene-birdiedoublered:
Re: Vented jackets
But at least with vented kit you'll be thermally comfortable as you impact your chosen solid object.
Re: Vented jackets
Ian wrote: Tue Aug 20, 2024 12:04 pm ... more likely to kill you than abrasions.
Impacts that cause an immediate 'stop' mean a lot of energy being lost, not good news.
But 'abrasion' might not mean just a bit of a graze.
As I always advise:
At the start of the day choose which type of crash you will have, then dress accordingly :thumbup:
Ian wrote: Tue Aug 20, 2024 12:04 pm Riding slower is much more likely to save your life.
:D
Re: Vented jackets
The Spin Doctor wrote: Tue Aug 20, 2024 8:40 am Have a look at the MotoCAP site... not only do you get an independent (ie - not designed by the industry to pass almost anything) destruction test on garments but they test them for waterproofing and breathability too.
Any views on Knox stuff - as not covered in that article?
Re: Vented jackets
Mr Moofo wrote: Tue Aug 20, 2024 5:54 pm Any views on Knox stuff - as not covered in that article?
Sorry... no idea.
