Soldering on a PCB
Beancounter
Has thanked: 3130 times
Been thanked: 684 times
Soldering on a PCB
Post by Beancounter »
The clocks on my Caponord have broken, lost the LCD display with the fuel gauge, temperature gauge and various other pieces of info. Capo owners tell me it's down to a failed capacitor shown in the image below.
Capo Capacitor.jpg (61.45 KiB) Viewed 1408 times
Apparently this is quite simple to remove and replace but it does require soldering a new one in place.
This is where I need advice please - soldering, specifically on to a PCB. I've soldered wires together before with reasonable if untidy success. My soldering irons are either a cheap gas job or a cheap mains powered one, usually the gas one to be fair because it's convenient.
Happy to buy a better soldering iron if it would make the job easier. Do I need flux? Do I need quality solder?
Ta.
Has thanked: 780 times
Been thanked: 3224 times
Re: Soldering on a PCB
Flux will make desoldering easier, and resoldering neater, but you can get away without it.
Soldering iron, if the tip is small enough and it gets hot enough what you have should be fine.
Quality solder is always best, I'm not going to recommend any particular brand as I still use my stash of leaded solder before nanny EU said I couldn't have it anymore.
Has thanked: 8048 times
Been thanked: 5698 times
Lutin
Has thanked: 369 times
Been thanked: 383 times
Post by Lutin »
You might want to have a look at this youtube video from Paul Carlson (Mr Carlson's Lab)
I suppose giving this technique a go on a scrap surface mount PCB would give you a tad more confidence.
Every PCB, these days, is populated with surface mount components and finding a scarp one shouldn't be too hard.
Lutin
Post by Lutin »
Count Steer wrote: Wed Jul 24, 2024 5:17 pm One of these might be useful too.
https://www.amazon.co.uk/Solder-Sucker- ... d_source=1
For surface mount stuff some solder wick (and flux) would be be more useful.
dern
Has thanked: 1187 times
Been thanked: 2281 times
Post by dern »
Old lead solder melts at a lower temperature I’ve found, if you can some it would make it slightly easier.
Pretty sure I've got some lead solder in my soldering kit. I'll have to have a rummage. IIRC it's not on a reel as I was given it for a project but the modern stuff was ok so I didn't use it all.
iansoady
Has thanked: 72 times
Been thanked: 244 times
Post by iansoady »
It's still available on ebay. https://www.ebay.co.uk/itm/176388752045
iansoady wrote: Sun Jul 28, 2024 4:12 pm It's still available on ebay. https://www.ebay.co.uk/itm/176388752045
Yeah, it seems the main no-no is for plumbing and it seems it's being 'phased out' generally. TBH, with a decent, temperature-adjustable soldering iron either tin/lead or lead free are OK for most jobs but for fiddly stuff on a PCB, lower temperature stuff might be pref.
Has thanked: 7636 times
Been thanked: 5937 times
I used to design PCBs. 20 layers, 18,000 connections, couple of thousand components (both sides) - but I know nurthing about fixing them :)
[Apart from that we had to design them to be fixable, otherwise the test bay people got upset]
Count Steer wrote: Sun Jul 28, 2024 4:20 pm Yeah, it seems the main no-no is for plumbing and it seems it's being 'phased out' generally
It's been a big no no in electronics for some time (2018 - 2019ish IIRC) thanks to RoHS, there are very specific exemptions that allow it's use when you absolutely must have low melting point stuff, but it shouldn't be available to general consumers
MrLongbeard wrote: Sun Jul 28, 2024 4:48 pm
Isn't the RoHS rule for PCB production environments? It doesn't appear to apply to home users (or lead soldier repairers :D ).
Mind you, my BiL (deceased) used to make lead weights for payphone handsets and that involved melting and casting the stuff in bulk...in his garage!
Count Steer wrote: Sun Jul 28, 2024 4:56 pm
RoHS is intended for manufacturers, but the wording can be a bit woolly and hobbyists can be thought of as a grey area, it applies to EEE, which can be but into the waste stream by anyone manufacturers and home tinkers alike.
I think we're on RoHS 3 now and every time its updated that crack down on substances and uses.
Ian
Has thanked: 1361 times
Been thanked: 581 times
Post by Ian »
Your main risk is the PCB tracks lifting if you heat it too much
I used a tiny 15W Antex with a tip about the size of a pencil lead for that sort of thing. As others have said lead solder melts sooner, I have some really thin lead solder (says size 10 it's like 30A fuse wire). I can send you some if you PM me your address tonight/ tomorrow but after that it'll be next weekend
You can reduce the risk by not trying to get the old leads out and just solder onto the pads. Mark the polarity before you take it out or there will be some head scratching
