CHEQUERED PAST: BSA LIGHTNING STREET TRACKER
Has thanked: 5449 times
Been thanked: 13085 times
Has thanked: 4359 times
Been thanked: 2850 times
Re: CHEQUERED PAST: BSA LIGHTNING STREET TRACKER
Like that. :thumbup:
Been thanked: 7526 times
Has thanked: 6375 times
Been thanked: 4750 times
The exhaust looks wrong. Otherwise, it's not particularly awful. :D
(It also gave me the flashback horrors of the experience of owning a BSA A7).
roadster
Has thanked: 15 times
Been thanked: 147 times
Post by roadster »
Count Steer wrote: Tue Jul 16, 2024 8:24 am The exhaust looks wrong. Otherwise, it's not particularly awful. :D
If you thought the A7 was bad rest assured the A65 was worse. I quite liked my burbling A10 and it took me 100s of miles with, as I found out later, broken piston rings. It was also a bit lop-sided as a result of previous sidecar use!
Quite why anyone would use that A65 engine in a special is beyond me but I assume it came with the frame (1972 oil in frame?) !
Has thanked: 15949 times
Been thanked: 10243 times
I don't dislike it, but there's something about it that doesn't sit right with me?
Ian
Has thanked: 598 times
Been thanked: 319 times
Post by Ian »
Needs a Spitfire tank the Lightning tank is to blobby.
I have an irrational love of A65s despite knowing how shit they are.
When I was in my early teens (early/mid 90's) my dad restored a '63 A65 Star twin and became a born again biker (he bought a brand new NTV650 too)
I've quite a soft spot for the A65... even if I did nearly brake my toe trying to change gear (with the rear brake).
Ian
Post by Ian »
Need more detail, how the heck did you break your toe? You must put some serious force into your gear changes!
It was kind of a joke.
I had to ride it to the village show, half a mile at most. I'd only ever ridden bikes with a left hand gear change, so I tired to change up with my left foot in a pair of cons.
Sadlonelygit
Has thanked: 85 times
Been thanked: 688 times
Post by Sadlonelygit »
Fond memories of the A44.......with a van full of devimead rebuilds
