Anyone upgraded to a 220 front disc?
Has thanked: 1829 times
Been thanked: 1469 times
Worth it or just this year’s over 800 mm handlebars?
Has thanked: 5450 times
Been thanked: 13085 times
Re: Anyone upgraded to a 220 front disc?
Nopes, I do get it of course but don't feel the need. Even the Orbea on a 180 stops me fine with Codes.
Taff
Has thanked: 255 times
Been thanked: 885 times
Post by Taff »
My Whyte comes with a 220f and 200r as standard with code REs and I've never wanted more brakes.
On the other hand my Canyon has 180s with sram DB8s, and my first singletrack DH section scared the shit out of me because I couldn't even slow down, never mind stop if I wanted to
That will be getting a 200 on the front when it's time to change, 200 is the max that Fox recommend for the fork.
Coming off Devils Dyke on Thursday I ran out of track and used a gate as a brake. Hence the question. Might give it a go!
Has thanked: 2941 times
Been thanked: 1883 times
Mr Moofo wrote: Sat Jun 29, 2024 10:06 pm Coming off Devils Dyke on Thursday I ran out of track and used a gate as a brake. Hence the question. Might give it a go!
Is your fork rated for a 220mm disc?
If it is then maybe treat yourself to a set of SRAM Maven's as they're rated for E-Bikes and the "larger set" Gentleman.
I'm on 200mm XT's (with disconcerting "Varibite" (c) Shimano feature) which stop me well enough.
The forks are Zebs - so I would guess so. Off to check
Yup - max 220 min 200
mboy
Has thanked: 527 times
Been thanked: 456 times
Post by mboy »
Very subjective, but definitely more functional than overly wide handlebars for most of us (I do know a couple of guys with shoulders wide enough to justify 800+ bars, but most people I know now trim them to the 760-780 range having realised there is such a thing as too wide)...
Lots of variables though... Your weight, your riding style, your bike, your tyres, your brake system, your brake pads, your ability to get a good bleed (or your mechanic's) on your brake system...
For me @ 95kg on a full fat eBike that has come with Deore 4 pots and 203mm rotors F&R and I'm finding the brake performance a little underwhelming, I'm contemplating a 220mm front rotor and a change of pads before I go committing to spending a significant amount of money on a brake upgrade...
If you're 60kg on a lightweight XC bike then I suspect it would be massively overkill!
mboy wrote: Sun Jun 30, 2024 7:02 pm
110 - and never really run out of braking capabilities on an MTB but have noticed that the E-MTB needs a lot more braking - hence the question.
mboy
Post by mboy »
Mr Moofo wrote: Sun Jun 30, 2024 7:36 pm 110 - and never really run out of braking capabilities on an MTB but have noticed that the E-MTB needs a lot more braking - hence the question.
Exactly... 👍🏻
220mm rotors aren't eBike specific, but they certainly make a lot more sense on an eBike, especially for those of us more "gravitationally challenged" than others!
The extra weight and momentum of an eBike really does tax the brakes quite a bit more.
mboy wrote: Sun Jun 30, 2024 9:03 pm
Exactly... 👍🏻
Never had an issue on regular manual bikes - other than cooking the discs at Morzine on the 161
millemille
Has thanked: 304 times
Been thanked: 1007 times
Post by millemille »
220 front and back. Standard sizes on the Focus, using Hope floating rotors and V4 E4 brakes and not lacking in braking power in the slightest even though I'm a fat fuck and the bike isn't even in the same postcode as light, probably knocking on the door of 25kg.
Maybe i'm missing something but i've not felt underbraked for many many years. Even the boy when riding the Rise doesn't come in saying he's under-braked and that's on a 180 CodeR. Maybe it says more about how me and him ride in some ways, but i don't profess to be a riding God that's for sure. But i'm more than happy on 180.
The Status is running 200s both ends and again, no issues at Dyfi, Antur, FoD etc... Sure maybe at the Alps in Aug it'll be found out, but that's arguably rider error rather than brakes :)
However, there's no reason to not go 220 if that's what you want, it'll add about 50gr of weight, so why not..
weeksy wrote: Mon Jul 01, 2024 7:12 am Maybe i'm missing something but i've not felt underbraked for many many years. Even the boy when riding the Rise doesn't come in saying he's under-braked and that's on a 180 CodeR. Maybe it says more about how me and him ride in some ways, but i don't profess to be a riding God that's for sure. But i'm more than happy on 180.
The boy weighs about 50kgs and has skills ...
Taff
Post by Taff »
Yeah but brake use has got a wired relationship with ability, when you're slow and shit (me) you need the bestest brakes cos your not good enough to carry the speed without crashing.
When you're pretty damn good, (you) you don't need so much brake because you can carry the speed.
When you're really fast (world cup level) you want the biggest bestest because the speed you carry is fucking ridiculous.
I know my place on that bell curve. 🥳
Turns out I have 220s on the front already! :oops: :oops: :oops:
Mr Moofo wrote: Sat Jul 06, 2024 10:17 pm Turns out I have 220s on the front already! :oops: :oops: :oops:
What are your brakes?
Taff
Post by Taff »
check the thickness of the disks, are they near or below the Min? maybe they just need a really good bleed and different pads. I really like the Galfer Purple pads, they work really well for me.
mboy
Post by mboy »
Just bought a 223mm Galfer rotor to replace the 203 on the front of my Orbea Wild.
Going to stick some upgraded pads in too...
Hopefully that'll fix the underpowered Deore 4pots, without having to spend any more money!
MingtheMerciless wrote: Sun Jul 07, 2024 10:39 am
Code Rs
