Beggars belief
- wull
- Has thanked: 880 times
- Been thanked: 1544 times
Beggars belief
This was too good not to share.
We secured a new contract with a local company that maintains grass bankings, grass areas around pathways etc. They were with another place but weren’t happy with them.
So they bring me in this John Deere lawnmower that has transmission problems, the wheels keep locking up. They had put it in to the other place and were told it was needing a new gearbox and had quoted £600, so I said I’d have a look see what’s what.
Here’s the mower, this was after I had fixed it, washed etc.
And here’s the slip from the other place, and next to it is all that was wrong with it the nut had got jammed in between the gear on the rear wheel and the gear on the output shaft from the gearbox. They clearly hadn’t bothered their arse to look and just quoted for a gearbox. Madness. Someone must have left it in there when they’ve had the wheel off, put the wheel on replaced the nut and at some point it’s finally got jammed causing the problem.
- Been thanked: 7530 times
- Has thanked: 7817 times
- Been thanked: 2528 times
Re: Beggars belief
It's the way of the true capitalist.KungFooBob wrote: ↑Thu Jun 20, 2024 3:32 pm So you're going to tell them it was the gearbox and only charge £500.
- Has thanked: 9828 times
- Been thanked: 10145 times
Re: Beggars belief
Wull,the too honest spanner jockey takes a pay cut this month.
- Has thanked: 6376 times
- Been thanked: 4753 times
Re: Beggars belief
Wull, the honest engineer gets a bonus for securing a new maintenance contract with a valuable customer.
- Has thanked: 2551 times
- Been thanked: 6244 times
- Has thanked: 85 times
- Been thanked: 688 times
Re: Beggars belief
This air filter has allegedly only been fitted for 30 miles by a KTM dealer.
They also missed 2 leaking fork seals and front pads at 1.4mm and a broken engine mount!
- Messenger_creation_aa660a35-b01a-48a1-8c2f-6299b7b68c05.jpeg (209.96 KiB) Viewed 288 times
- Has thanked: 15955 times
- Been thanked: 10246 times
Re: Beggars belief
Ahh, defeat snatched from the jaws of victory!Mr. Dazzle wrote: ↑Thu Jun 20, 2024 4:33 pm wull gets no credit whatsoever and just another job to do most likely
Re: Beggars belief
Are you a girl? As girls get charged more as they know nothing. Such as charging for a cabin filter and fitting of 1/2 hour labour when there isn't one. Also spark plugs that are 100km spark plugs that were changed 10k ago.Sadlonelygit wrote: ↑Thu Jun 20, 2024 5:14 pm This air filter has allegedly only been fitted for 30 miles by a KTM dealer.
Re: Beggars belief
Not the last time I looked!katana wrote: ↑Thu Jun 20, 2024 5:39 pmAre you a girl? As girls get charged more as they know nothing. Such as charging for a cabin filter and fitting of 1/2 hour labour when there isn't one. Also spark plugs that are 100km spark plugs that were changed 10k ago.Sadlonelygit wrote: ↑Thu Jun 20, 2024 5:14 pm This air filter has allegedly only been fitted for 30 miles by a KTM dealer.
Not my bike, but that of an innocent wide eyed teenager
Spark plug had a 1.2mm gap!!
