Ahoy there sparkies!
Trogladyte
Has thanked: 68 times
Been thanked: 89 times
Post by Trogladyte »
I have a conundrum.
In the hall downstairs there are two lights that operate together, controlled by two switches, at opposite ends of the hall. Its a pretty standard setup. The bulb at the kitchen end blew, and i kept forgetting to fix it. And then I noticed hat the bulb at the front door end would not switch off completely. Switched on it is bright, but switched off it is dim. If I replace the blown bulb with a 15w LED this behaviour continues - switch on, and both lights on. Switch off and the kitchen end goes off, and the front door end goes dim. If I replace the bulb at the kitchen end with an incandescent, it all works normally.
The only thing that is noticeably different to standard that i can see is the switch at the kitchen end, which is a light sensitive thing that can be set t turn the lights on at night when you are on your hold, but it is switched to normal operation, and I cant see how that could cause this effect.
Thoughts?
Has thanked: 6187 times
Been thanked: 5087 times
Re: Ahoy there sparkies!
Your house is haunted. Move immediately?
Wreckless Rat
Has thanked: 666 times
Been thanked: 704 times
Post by Wreckless Rat »
Take off and nuke the entire area, it's the only way to be sure...
Been thanked: 7526 times
Sounds like an Earth Leak, the Earth is leaking the souls of the dead into your house.
Has thanked: 9819 times
Been thanked: 10144 times
Shoggoths in the wiring. :shock:
Has thanked: 10263 times
Been thanked: 6885 times
Same here on lower staircase . All 3 lights emit a light glow which is just enough to see by at night :)
Our sparky explained it away.
Has thanked: 836 times
Been thanked: 1238 times
I've had this occasionally, I suspect it's lights that use transformers. Because a transformer is still connected to neutral when switched off it still gets a sine wave on one side which is possibly enough to produce a small current.
I've never looked into this properly so it's a guess.
crust
Has thanked: 604 times
Been thanked: 515 times
Post by crust »
My guess would be the photoswitch in the kitchen.
It's most likely a semi-conductor switch so will not mechanically break the circuit like a normal on/off switch.
