Talk to me about braking with the rear brake
- Has thanked: 16272 times
- Been thanked: 3747 times
I know, I know - 99.9% of bikers don't ever use the rear brake and it's basically useless!!!
I used to be similar TBF - but now, for me, downhill braking with the front is currently causing a fair bit of pain through my elbow.
And I know that this is probably yet another stupid question, but I feel like all the things I used to do instinctively/naturally I am having to relearn - this time without people to help
I'm trying to reprogram to use the rear a lot more, especially downhill. Downsides are that I'm used to riding with my toes on the pegs, I have tiny feet (relative to my height!) so the 'reach' to the rear brake makes rear braking unexpectedly more difficult; and, for now, due to a lack of decent core muscles, gripping the tank and staying upright whilst moving my right foot can feel a bit odd!!
So -
When are we supposed to use it?
Why do you use it? (for those that do!!)
Please be a bit gentle - K.I.S.S. kinda stuff as too wordy and my brain does not play the reading game
So -
- Has thanked: 10117 times
- Been thanked: 6649 times
Re: Talk to me about braking with the rear brake
I use the rear brake for slow speed manoeuvres, revs up and control speed with rear brake. Basic bike skills. Whilst riding, as you say, going down hill you are better off not putting too much on the front end.
I've been trying not change too much, but yes, now I have realised how awkward downhill braking is, I may have to do that
- Has thanked: 5945 times
- Been thanked: 4933 times
Really? Errr no, not really.
1. Find out whether it works. Empty car park, 25-30mph, straight line, gradually increase pressure
2. Find out what braking system it is (ABS, or linked, etc)
3. If you want to slow a lot, use the front brake
4. As you brake harder, the bike's weight is more over the front, so the rear brake can't be as effective
5. Front brake is designed to stop you from high speeds, rear better at lower speeds
6. See '5'. Grab the front in a slow tight turn = fall. See '2' if linked, rear will apply some front too.
7. See '6', use to SLOW - not STOP - in tight turns.
8. See '7'. To stop in a tight turn, bring the bike up and straight, then stop.
Probably should have put one of these or after the statement!!
But if you think back to when I was asking about the rear brake on the Monster, virtually everyone told me not to worry about it as it's a nice to have, not a necessity!!
I really don't agree, probably more to do with where I live than anything else as I know I rarely used the rear in the uk!!
Definitely worksHorse wrote: ↑Sun May 26, 2024 4:52 pm 1. Find out whether it works. Empty car park, 25-30mph, straight line, gradually increase pressure
3. If you want to slow a lit, use the front brake
4. As you brake harder, the bike's weight is mire over the front, so the rear brake can't be as effective
8. See '7'. To stop in a tight turn, bring tge bike up and straight, then stop.
Need to check the info on the bike/age cos I'm not 100% sure - but I learnt to ride on a Blackbird with linked brakes, so am ok with them
And thanx. Makes sense and is what I thought, but I'm kinda second guessing myself at the moment in my 'relearning' process
- Has thanked: 626 times
- Been thanked: 4072 times
I use the rear brake all the time, braking is more stable if you use the front and rear brakes together, it's how I ride, I find a bike with no rear brake very difficult to ride.
Moi aussi, M. Fromage.Le_Fromage_Grande wrote: ↑Sun May 26, 2024 5:21 pm I use the rear brake all the time, braking is more stable if you use the front and rear brakes together, it's how I ride, I find a bike with no rear brake very difficult to ride.
Many riders use the front brake only when coming to a stop. I much preferred the rear brake for the last 'nip'. Probably from riding stodgy-suspension tourers
- Has thanked: 601 times
- Been thanked: 390 times
It's really only for steadying a wheelstand if you're about to go over the back. Otherwise it's a bit nesh.
Funnily enough, John McGuinness told me that one day - then admitted it hadn't worked for him as he'd broken a bone in his hand messing up a wheelie on an off roader!!MyLittleStudPony wrote: ↑Sun May 26, 2024 5:30 pm It's really only for steadying a wheelstand if you're about to go over the back. Otherwise it's a bit nesh.
I know I know - claim to fame!!
- Has thanked: 9690 times
- Been thanked: 9704 times
It's a very useful tool on almost any road bike. All the slow stuff and U turns would be less easy without a rear brake. Many a time it's pulled me out of the fire when I've dicked a bend,or encountered muck/gravel. Essential tool for the kit.
I see so many bikers trailing their legs awkwardly when in traffic,or slowing down,they're strangers the the magic of the rear brake and the clutch biting point.
My H1 may as well have no brakes if I didn't use the rear,but that's a different story!
I suspect that one of the reasons I've not often used the rear brake is that it was always a challenge to 'get' to it (size 4 feet, sometimes size 5 boots!). I am not sure now how much, if any, adjustment was available on the various bikes, but I suspect I learnt to ride without mostly because it was difficult to get to it. Maybe, but also I was 'babied' by having linked brakes on the BB when I learnt.
Will see if I can get someone to help me adjust it for easier reach (and make a note of the original settings for return to owner!!). I have been using it more the last week, mainly because it reduces the pain in my arm (elbow mostly!) if I don't use the front brake!! The joys of being a spazz
Thank youSkub wrote: ↑Sun May 26, 2024 5:42 pm It's a very useful tool on almost any road bike. All the slow stuff and U turns would be less easy without a rear brake. Many a time it's pulled me out of the fire when I've dicked a bend,or encountered muck/gravel. Essential tool for the kit.
I'm definitely using more now here - the roads are a bit different to back home!! LOL
Maybe I used it more than I remember. (Long time etc etc all automatic etc etc ).
- Has thanked: 2632 times
- Been thanked: 1498 times
If it's steel, it wouldn't be that difficult to 'cut and shut' it to make it a bit shorter.Noggin wrote: ↑Sun May 26, 2024 5:46 pm I suspect that one of the reasons I've not often used the rear brake is that it was always a challenge to 'get' to it (size 4 feet, sometimes size 5 boots!). I am not sure now how much, if any, adjustment was available on the various bikes, but I suspect I learnt to ride without mostly because it was difficult to get to it. Maybe, but also I was 'babied' by having linked brakes on the BB when I learnt.
Or you could do what Gerald did, long ago on another planet connected to Earth via the Compuserve motorcycle forum and create your own version of the 'Spoon Boot'...
He hammered a spoon flat in his garage, then heated the handle end up, and melted it into his boot, heaving the flat bit projecting out so he could reach the gearshift!
I'm not kidding.
If we're still talking CBF1000, then it also has linked brakes, IIRC one of the three pistons in the rear come on with the front.
I always use the rear when slowing from high speed, e.g. coming to a roundabout on a dual carriageway, I'll be braking with both because I feel that the bike is more 'level' and stable, as I'm tipping into the roundabout I'll be letting off the front but may keep dragging the rear for a little bit longer
- Trinity765
- Has thanked: 2420 times
- Been thanked: 2318 times
I use rear brake all the time. For slow control, downhill, especially if it's slippery and I use both brakes for slowing down and stopping. If I trail brake I release the front brakes before the back brake for stability.
It was something that I had to practice as it didn't come naturally and my ankle was stiff to begin with but now I do it all of the time subconsciously.
Lockdown refugee
Did some experiments when a trainee had a Honda with linked brakes. Definitely smoother e-stops when using both hand and foot controls (can't really say 'both brakes when they're linked!).Taff wrote: ↑Sun May 26, 2024 6:40 pm If we're still talking CBF1000, then it also has linked brakes, IIRC one of the three pistons in the rear come on with the front.
Is that 'always', or 'just on occasiins when trail braking'?
If 'always' that means you're limiting your options if something changes, carrying speed late into the junction.
I pretty much only ride to get to work and back, same roundabouts twice a day and they have really good visibility... One of them is a roundabout in the middle of a dual carriageway with no other junctions, it's straight on or u turnHorse wrote: ↑Sun May 26, 2024 8:13 pmDid some experiments when a trainee had a Honda with linked brakes. Definitely smoother e-stops when using both hand and foot controls (can't really say 'both brakes when they're linked!).Taff wrote: ↑Sun May 26, 2024 6:40 pm If we're still talking CBF1000, then it also has linked brakes, IIRC one of the three pistons in the rear come on with the front.
I can't do any major adjustments, it's not my bike!!! LOLThe Spin Doctor wrote: ↑Sun May 26, 2024 6:38 pmIf it's steel, it wouldn't be that difficult to 'cut and shut' it to make it a bit shorter.Noggin wrote: ↑Sun May 26, 2024 5:46 pm I suspect that one of the reasons I've not often used the rear brake is that it was always a challenge to 'get' to it (size 4 feet, sometimes size 5 boots!). I am not sure now how much, if any, adjustment was available on the various bikes, but I suspect I learnt to ride without mostly because it was difficult to get to it. Maybe, but also I was 'babied' by having linked brakes on the BB when I learnt.
I'm not kidding.
And as I spend a fair amount of time walking in my boots, I can't see me adding anything!! LOL
will have to look and see what adjustment there is on position, if none, might look at the price of aftermarket ones if they are different. If not, will have to learn to move my foot more!!!
I'm not 100% sure I noticed the difference if I'm completely honest, but then I wasn't an experienced rider and did (still do) just ride what I had without being technical . I did delink the brakes on the last BB but just because I felt I should ride a bike that had two brakes and learn better! Not sure that worked if I can't remember what I used to do!! LOLHorse wrote: ↑Sun May 26, 2024 8:13 pmDid some experiments when a trainee had a Honda with linked brakes. Definitely smoother e-stops when using both hand and foot controls (can't really say 'both brakes when they're linked!).Taff wrote: ↑Sun May 26, 2024 6:40 pm If we're still talking CBF1000, then it also has linked brakes, IIRC one of the three pistons in the rear come on with the front.
It is good to see a few posts confirming that rear brakes are a good/useful thing - I did feel the general feeling was that I was being a wuss when I was trying to get the rear brake working on the Monster!! LOL But, whilst I managed in general, down a mountain full of hairpins in the wet was something I never did simply cos of the lack of rear brake!!!
It definitely doesn't come naturally to me, but 20 ish years of riding without really using it is probably the issue!! LOL I can see the need for it and I suspect that I did use it in some of the situations you and others mention. But it seems so long ago that I really can't remember what I sued to do Downside of going from riding like a raving loony anytime I could, to not riding! Just a handful of times 'not every year' since 2017Trinity765 wrote: ↑Sun May 26, 2024 7:25 pm I use rear brake all the time. For slow control, downhill, especially if it's slippery and I use both brakes for slowing down and stopping. If I trail brake I release the front brakes before the back brake for stability.
It's basically why I'm asking what I know could be perceived as stupid questions. I really just can't remember what I used to do. Sometimes it's just to check that I am doing what I think I should but am not sure. But, like with this braking thing, I really need some clarification before I go play (maybe tomorrow if it's not p'ing down!) and then I'll probably work out what I was doing or at the least, work out what I should be doing!! LOL
Far too complicated having to relearn on my own!!
It sounds like you're over thinking riding, do what feels right on the bike and only go as fast as you feel safe and you won't go far wrong.
