What's it called and where can I get it done?
- Has thanked: 29 times
- Been thanked: 344 times
I have an idea for her anniversary present this year.
I want to preserve! a plastic clothes peg in resin.
The peg is special ok!
I've seen flower preservation, but pretty sure a peg doesn't need that level of preparation.
Is it something you could do yourself with a suitable mould, or anyone on here do this kind of thing?
Tia
Tia
- Has thanked: 2490 times
- Been thanked: 5707 times
Re: What's it called and where can I get it done?
Casting resin you mean?
These guys sell it and all the gubbins you'd need. You can probably also find it cheaper elsewhere, but I can highly recommend Easy Composites as 'legit'. I used their stuff at work, even when I worked for a composites company![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
I bet there are loads of instructional vids on YouTube. There's also some info on EC's website.
https://www.easycomposites.co.uk/casting-resins
- Location: For legal reasons everything I post is a joke
- Has thanked: 507 times
- Been thanked: 6763 times
How do you stop the peg from sinking to the bottom before it sets?
Do it in two layers?KungFooBob wrote: ↑Wed May 22, 2024 11:09 am How do you stop the peg from sinking to the bottom before it sets?
Edit: I know fuck all about this btw, but I make a mean trifle.
- gremlin
- Has thanked: 681 times
- Been thanked: 4031 times
I know all about this, as a resin piece featured in the Gremlinette's art GCSE work (A*, thanks for asking
Create the form, mix the resin, pour and push the object in. As said, you can it in layers if the object is heavy to stop it sinking to the bottom.
In fact, I have a resin kit sat in a drawer that never got used, just waiting for a project...
![Wink ;)](./images/smilies/icon_e_wink.gif)
Or do it in zero g.Slenver wrote: ↑Wed May 22, 2024 11:19 amDo it in two layer?KungFooBob wrote: ↑Wed May 22, 2024 11:09 am How do you stop the peg from sinking to the bottom before it sets?
I suggest this all the time at work as the solution to all kinds of problems, no matter how effective it would be no-one ever goes for it
![Sad :(](./images/smilies/icon_e_sad.gif)
I mean, it's not hard is it? Just find a friend with a pilot's licence and get him to stall it from a goodly height.Mr. Dazzle wrote: ↑Wed May 22, 2024 11:26 amOr do it in zero g.Slenver wrote: ↑Wed May 22, 2024 11:19 amDo it in two layer?KungFooBob wrote: ↑Wed May 22, 2024 11:09 am How do you stop the peg from sinking to the bottom before it sets?
I suggest this all the time at work as the solution to all kinds of problems, no matter how effective it would be no-one ever goes for it![]()
How long does it take to set?
- gremlin
Long enough that it would be a peg, bone fragments and part of your spleen in the resin.Slenver wrote: ↑Wed May 22, 2024 11:31 amI mean, it's not hard is it? Just find a friend with a pilot's licence and get him to stall it from a goodly height.Mr. Dazzle wrote: ↑Wed May 22, 2024 11:26 amOr do it in zero g.
That sounds sub-optimalgremlin wrote: ↑Wed May 22, 2024 11:35 amLong enough that it would be a peg, bone fragments and part of your spleen in the resin.Slenver wrote: ↑Wed May 22, 2024 11:31 amI mean, it's not hard is it? Just find a friend with a pilot's licence and get him to stall it from a goodly height.Mr. Dazzle wrote: ↑Wed May 22, 2024 11:26 am
Or do it in zero g.
How long does it take to set?![]()
Will that work in a R22?Slenver wrote: ↑Wed May 22, 2024 11:31 amI mean, it's not hard is it? Just find a friend with a pilot's licence and get him to stall it from a goodly height.Mr. Dazzle wrote: ↑Wed May 22, 2024 11:26 amOr do it in zero g.
- MrLongbeard
- Has thanked: 520 times
- Been thanked: 2099 times
Expect bubbles, unless you've got a vacuum chamber or pressure pot
Don't see why notSadlonelygit wrote: ↑Wed May 22, 2024 11:48 amWill that work in a R22?Slenver wrote: ↑Wed May 22, 2024 11:31 amI mean, it's not hard is it? Just find a friend with a pilot's licence and get him to stall it from a goodly height.Mr. Dazzle wrote: ↑Wed May 22, 2024 11:26 am
Or do it in zero g.
- Potter
- Has thanked: 2183 times
- Been thanked: 4535 times
It’s interesting.Mr. Dazzle wrote: ↑Wed May 22, 2024 11:26 amOr do it in zero g.Slenver wrote: ↑Wed May 22, 2024 11:19 amDo it in two layer?KungFooBob wrote: ↑Wed May 22, 2024 11:09 am How do you stop the peg from sinking to the bottom before it sets?
In another life I had a job where we’d get to occasionally play about with pressures in a sealed system to control the temperature when stuff turns to a gas and I found it really interesting, e.g. you can hold water in a vessel well over 100c without it boiling using system pressure.
There is a neat trick of making water freeze by squeezing the plastic bottle and changing the pressure if you get it just right.
Rather than perform a parabolic arc, imeSlenver wrote: ↑Wed May 22, 2024 11:52 amDon't see why not
"Well over" is underselling itPotter wrote: ↑Wed May 22, 2024 12:00 pm It’s interesting.
Once you get really hot though 'water' and 'steam' start to become the same thing. Power stations run over on the right of this graph where green and yellow overlap, once you're above the critical point water and steam are essentially the same thing - or they're some other thing with a different name, depends what you want to call it.
Whatever you call it, you certainly don't want a leak
![Surprised :o](./images/smilies/icon_e_surprised.gif)
![Image](https://upload.wikimedia.org/wikipedia/commons/thumb/3/33/Phase_diagram_of_water_simplified.svg/1280px-Phase_diagram_of_water_simplified.svg.png)
- Has thanked: 5846 times
- Been thanked: 4247 times
I've seen IG stuff where they make 'river tables' by pouring stuff into gaps between slices of tree. Single or multiplepour. They don't seem to have bubble problems. 2 part epoxy, low exotherm. This is listed as 'deep pour epoxy river table resin' but the company does lots of stuff, some sorts are on Amazon.
https://www.clearcastresins.co.uk/deep- ... n-29-p.asp
Re: bubbles - we always used to Degas resin (when making certain kinds of carbon fibre) in a vacuum chamber. Basically mix it up, stick it in the vacuum chamber, draw a vacuum and watch the resin bubble up like just poured champagne. Wait for the bubbles to disappear and then you're good.Count Steer wrote: ↑Wed May 22, 2024 12:09 pm I've seen IG stuff where they make 'river tables' by pouring stuff into gaps between slices of tree. Single or multiplepour. They don't seem to have bubble problems. 2 part epoxy, low exotherm. This is listed as 'deep pour epoxy river table resin' but the company does lots of stuff, some sorts are on Amazon.
Surface bubbles on wet resin can be dealt with using a blow torch.
- Potter
Well yeah, I didn't want to be too boringMr. Dazzle wrote: ↑Wed May 22, 2024 12:07 pm
"Well over" is underselling itYou can get water way higher than 100°C with the right pressure, and indeed even 'normal' power stations run up well into the hundreds and hundreds of celsius.
![Laughing :lol:](./images/smilies/icon_lol.gif)
I have a few questions that I used to throw out in interviews to immediately see where someone was at, one of them was "How can I make a cup of water boil at 70c?"
It's a very easy question, but if you don't know then you don't know.
Back onto the subject, there are some brilliant videos on Youtube of people making tables and things using resin and bits of all sorts of things, I particularly like the old wood and resin tables, you can use coloured resin and make some really nice stuff. It's on my list of things to do once I've retired and got time to bugger about.
- Has thanked: 2820 times
- Been thanked: 1777 times
My old physics teacher used to do an experiment where he could get water boiling at about 38C, pointing out that that this was why tea at altitude tastes rubbish.Potter wrote: ↑Wed May 22, 2024 12:25 pmWell yeah, I didn't want to be too boringMr. Dazzle wrote: ↑Wed May 22, 2024 12:07 pm
I once spent about 40 mins cooking rice in Breckenridge CO (altitude 9500ft) and wondering why it was still pretty al dente ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
