Stairlift - can they be rented?? (England/London)
- Has thanked: 16210 times
- Been thanked: 3925 times
Ok, calm down, it's not for me!!
A mate needs to rent a stairlift for his mum while she waits for a hip replacement op.
His address is SW16 but she’s near Chelmsford.
I've suggested he ask someone like Age Concern but also remembered that you guys have various older relatives and wondered if anyone has had to deal with this and could help with any advice on sourcing one?
Cheers
Cheers
- Has thanked: 6191 times
- Been thanked: 5087 times
Re: Stairlift - can they be rented?? (England/London)
Do you mean the seat things?
The only ones I've seen have required substantial installation. Bolted in, mains supply, etc. Not a simple job.
Best contact the suppliers.
- Yambo
- Has thanked: 598 times
- Been thanked: 1647 times
I can't answer your question but the NHS said we could have one, on them, when Mrs Y was a few months on from a diagnosis of terminal cancer.
I suspect that a hip replacement won't be grounds enough for a stannah though.
Co-incidentally, I need a hip replacement (but I don't want to pay for it) and walking can be difficult but climbing stairs (up and down) is no problem. I guess it's down to where the cartilage has worn away in the joint.
- Has thanked: 1042 times
- Been thanked: 362 times
My sister rented one when she had her hip replaced.
I’ll ask her.
I’ll ask her.
- Has thanked: 6376 times
- Been thanked: 4753 times
Most deals seem to be rentals/lease. ie £400-500 fitting/removal charge + monthly charge but I assume they expect them to be in place for a reasonable length of time (may be a minimum period?).
Dunno how these things are fitted but if it involves drilling walls etc I'd be a bit worried about redecorating costs.
(I just Googled 'stairlift rental UK' and 3 or 4 seem to be the same sort of deal).
Late F-i-L's was in their place when bought it, about 30 years ago. Fixed to the wall and stairs. Plus mains supply.Count Steer wrote: ↑Sat May 18, 2024 7:33 am Dunno how these things are fitted but if it involves drilling walls etc I'd be a bit worried about redecorating costs.
- Has thanked: 836 times
- Been thanked: 1239 times
I lived in a house that used to have a stair lift fitted, I only found out when someone told me that's why there was a power socket at the bottom of the stairs. I remember being surprised and expecting there to be filled in holes in the walls but there was no sign.Count Steer wrote: ↑Sat May 18, 2024 7:33 am Most deals seem to be rentals/lease. ie £400-500 fitting/removal charge + monthly charge but I assume they expect them to be in place for a reasonable length of time (may be a minimum period?).
(I just Google 'stairlift rental UK' and 3 or 4 seem to be the same sort of deal).
How long ago was that? I suspect the modern ones take a lot less supporting than the olde worlde ones, they seem to be little more than a motorised plastic pad and a rail. I guess the lightweight jobs have passenger weight constraints though.Mussels wrote: ↑Sat May 18, 2024 8:16 amI lived in a house that used to have a stair lift fitted, I only found out when someone told me that's why there was a power socket at the bottom of the stairs. I remember being surprised and expecting there to be filled in holes in the walls but there was no sign.Count Steer wrote: ↑Sat May 18, 2024 7:33 am Most deals seem to be rentals/lease. ie £400-500 fitting/removal charge + monthly charge but I assume they expect them to be in place for a reasonable length of time (may be a minimum period?).
