Is this worn (car) tyre legal
MyLittleStudPony
Has thanked: 616 times
Been thanked: 407 times
Post by MyLittleStudPony »
It's worn on the outer edge. The rest has 2-3mm of tread.
I can get it changed on Monday via a major tyre website. Do you think it's ok to use until then or should I try and get it done asap?
tyre (Medium).jpg (309.04 KiB) Viewed 261 times
Has thanked: 1816 times
Been thanked: 1164 times
Re: Is this worn (car) tyre legal
Looks suspect, is there any rain forecast?
dern
Has thanked: 1016 times
Been thanked: 1767 times
Post by dern »
The legal side of it is... "Tyre tread depth has to be above 1.6mm to be legal. This must be the case for the middle three quarters of the tyre."... so I'd say you're ok.
I would only change it before Monday if I was doing a long drive and rain was forecast.
Been thanked: 7530 times
From...
https://www.rac.co.uk/drive/advice/tyre ... the%20tyre.
MyLittleStudPony
Thanks chaps. I'll be aware of it and get it done on Monday.
Sadlonelygit
Has thanked: 85 times
Been thanked: 688 times
Post by Sadlonelygit »
Get the tracking done as well!
Sadlonelygit wrote: Thu Apr 25, 2024 12:17 pm Get the tracking done as well!
Or go slower round corners
MyLittleStudPony
My instinct was the wear was from ganning it round roundabouts rather than tracking.
Part of me also thinks tracking and wheel alignment is the biggest scam in motoring.
Has thanked: 9828 times
Been thanked: 10145 times
Never mind tyres....you know the drill. :thumbup:
dern
Post by dern »
MyLittleStudPony wrote: Thu Apr 25, 2024 1:29 pm Part of me also thinks tracking and wheel alignment is the biggest scam in motoring.
It's definitely not. It makes a big difference to stability in handling and braking and dramatically affects tyre wear. Your tyre looks evenly worn though. I'd put the edge wear down to enthusiasm. The centre wear marks look like you've reached that depth of tread but it doesn't look like you've reached the two either side quite yet which would suggest that it might be (or have been) slightly over inflated.
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Post by Yambo »
Is that the same part of you that thinks the world is flat? :D
MyLittleStudPony
dern wrote: Thu Apr 25, 2024 2:00 pm
That is spot on! :thumbup: I do keep the pressures on the high side and like to whang it round corners and roundabouts.
