Crazy engineering stories?
- Been thanked: 2617 times
Re: Crazy engineering stories?
I used a turned piece of oak as an adapter from the downpipes to the end can on my R100GS. It lasted long enough to convince to make a stainless steel one.
- Has thanked: 2942 times
- Been thanked: 1883 times
Continuing the wood theme, the firm I apprenticed with made power transformers. One particular transformer design had an on load tap changer, the shaft of which was made of a super compressed/pressurised laminate wood. The shaft was made of an inch square section of the bastard stuff. It was so dense and strong that it would take several hacksaw blades to cut through it.
- Has thanked: 1295 times
- Been thanked: 872 times
There’s a subreddit called Justrolledintotheshop which has some pretty spectacular auto bodges/neglect /fuckwittery.
- Has thanked: 85 times
- Been thanked: 689 times
My gramps had a Morris garage between the wars and I was told stories of wooden pistons, sawdust in gearboxes/diffs.
- Has thanked: 1508 times
- Been thanked: 1412 times
More than a few seized Kaw H2's were sold with a tennis ball on the con-rod of the seized cylinder. "It's only running on two, I think it fouled a plug...."
- Has thanked: 9828 times
- Been thanked: 10145 times
I once bought a fairly new,but disassembled (in boxes) Honda dirt bike,some time in the 90s. I think I paid 50 quid or so. On further investigation some bright spark in order to remove the crank,sawed through the crankcases....
