Glue Needed.
Has thanked: 10261 times
Been thanked: 6885 times
Glue Needed.
On the freezer door, the rubber seal has come away at the bottom. About 9".
Causing a slight leak.
Just wondering what sort of glue to use.
Ideally without defrosting the fridge, so the door would have to be closed instantly.
What glue works instantly and doesn't mind very cold temperatures?
Ta :)
DefTrap
Has thanked: 2259 times
Been thanked: 2190 times
Re: Glue Needed.
Post by DefTrap »
I'd try super glue first, just make sure the surfaces are dry.
Has thanked: 2402 times
Been thanked: 3625 times
Re: Glue Needed.
My go-to glue/filler is CT1 - don't know if it's available in the coal mine. It's a hybrid polymer, so others of the same type should do the job. They reckon it even works underwater, though I've never tried that...
Has thanked: 2550 times
Been thanked: 6241 times
Re: Glue Needed.
mangocrazy wrote: Sat Mar 23, 2024 7:03 pmThey reckon it even works underwater, though I've never tried that...
Most glues which cure rather than dry would work underwater TBF, thinking about it. So silicones, epoxies, cyanoacrylates (super glue), polyurethanes...loads.
It'd be the cold which would stop it I reckon, not so much the wet. Don't start with Araldite :D
Has thanked: 2903 times
Been thanked: 2052 times
Re: Glue Needed.
Try 3M VHB double sided tape, if you can get it.
Re: Glue Needed.
ChrisW wrote: Sat Mar 23, 2024 8:54 pm Try 3M VHB double sided tape, if you can get it.
Good thinking
Has thanked: 1507 times
Been thanked: 1410 times
Re: Glue Needed.
3M Weather Strip glue (aka Gorilla snot)
Yambo
Has thanked: 598 times
Been thanked: 1647 times
Re: Glue Needed.
Post by Yambo »
The double sided tape or a contact adhesive would be my choices.
