Orbea Rise M10 eBike, custom build, size Large, very high spec, vgc... £4,250
mboy
Has thanked: 625 times
Been thanked: 549 times
Post by mboy »
Selling my Orbea Rise M10, full custom build… Spec in the pics is changeable (happy to discuss options)… Or happy even to sell as a rolling chassis.
The bike has done a mere 130 miles!!! I have owned it for 2 years, but contracted bowel cancer, and spent more than 18 months not being able to ride a bike during that time. Now selling to fund a full power ebike now I can start cycling again.
Spec as follows…
-2022 Orbea Rise M10 frameset, green, Large, Invisiframed from new.
-Shimano EP8 RS motor with 360Wh internal battery
-Shimano SCE7000 display on bars
-Fox Float X Factory 210×55 shock custom tuned by Dirt Works Bikes
-Fox 36 Factory 150mm fork (160mm shaft available) custom tuned by Dirt Works bikes, currently fitted with Diaz Runt air spring cartridge.
-Choice of 170mm E13 cranks, 165mm XTR cranks (pictured), or 160mm XT cranks.
-Fox Transfer Post 31.6 x 175mm drop
-Original Fizik Taiga saddle (not pictured)
-SRAM X01 Eagle 12spd mechanical rear mech, shifter and cassette (or can be swapped out for brand new unused 12spd XT/SLX combo and price adjusted)
-SRAM Code RSC Brakes (not pictured) with 200/180 rotors (or can be swapped out for Deore 4 pots if preferred)
-Mavic Deemax 29 wheels with Maxxis tyres (not Schwalbe pictured)… Or if preferred have DT Swiss 350’s on Oquo rims or SRAM hubs on Raceface rims and price can be adjust accordingly.
-Thomson X4 40mm stem (or cheap 50mm unbranded stem)
-Nukeproof Horizon Carbon bar (or Raceface Atlas)
The bike is also now fitted with a Cascade Link (increases rear travel from 140 t0 150mm and stiffens the rear triangle too) which I will leave on, or can remove and refit the original link and knock £250 off the price…
Also included is a brand new 252Wh Range extender that has never been used!
So at £4,250 it’s not the cheapest Carbon Rise for sure, but you’re getting a HUGE spec and its immaculate with minimal miles… Or for £3k I could build it up with cheaper parts, remove the Cascade Link, no range extender, no Diaz Runt etc…
Time is of the essence here… I’m not about to entertain stupid offers, but we are trying to sell our house currently and my new bike arrives imminently. So please if you’ve got questions about a possible price, spec etc. or even would just like to buy the frame/motor/battery/fork combo etc. then give me a shout, I’m sure we can come to an agreement…
Based in Worcester but do travel a bit for work anyway. Ideally do not want to post because of the weight and value.
