Renault Trafic help for a dinosaur please!!!
Has thanked: 16222 times
Been thanked: 3927 times
The auto Trafic I generally drive went to the garage last week to fix some sensors
Now, for the first time the lane assist noise is working 🙄🙄
I have no idea if it was ever on before but it sodding well is now
Anyone know how to turn off the lane assist on a 2022 Trafic Auto??
This photo is the dash and steering wheel controls. I’ve pushed/messed with everything that looks like it’s to do with LA, but nothing has changed :( :( :(
Got a pick up in about an hour so not expecting miracles before the, but -
Heyulp!!!!
Has thanked: 2552 times
Been thanked: 6257 times
Re: Renault Trafic help for a dinosaur please!!!
Should be a button down on the left.
https://ie.e-guide.renault.com/eng/Traf ... nt%20panel.
Awesome. Thank you. I hadn’t found that button. Will go check after I’ve had coffee 🤞🏻🤞🏻🤞🏻
Saga Lout
Has thanked: 566 times
Been thanked: 756 times
Post by Saga Lout »
Noggin wrote: Sat Feb 24, 2024 8:30 am Awesome. Thank you. I hadn’t found that button. Will go check after I’ve had coffee 🤞🏻🤞🏻🤞🏻
If that fails:
RTFM.
Saga Lout wrote: Sat Feb 24, 2024 9:58 am
If that fails:
RTFM.
She did.
After I told her which page to look on ;) Wouldn't mind betting said manual is built into the van too :D
Been thanked: 7535 times
Try driving been the lines :)
Also, indicate when changing lanes as that'll turn it off while you compete your manoeuvre.
Van might also have steering assist/nudge to keep you on the straight on narrow. Depending on how brave you are, you can let go of the steering wheel for quite a long time.
Maybe don't try it on Alpine passes though. Not unless you've got a pallet of gold bullion in the back.
I'm enjoying the optimism of that speedo too.
Been thanked: 2618 times
KungFooBob wrote: Sat Feb 24, 2024 10:05 am Try driving been the lines :)
They are fun to drive on single track roads, an almost constant vibration.
Has thanked: 218 times
Been thanked: 689 times
Mr. Dazzle wrote: Sat Feb 24, 2024 10:15 am
That'll be those short europy miles.....
Yeah I know. :D
TBF it doesn't need to go any higher, its probably speed limited to 250kph/155mph like most European vehicles ;)
Mr. Dazzle wrote: Sat Feb 24, 2024 10:02 am
If that fails:
RTFM.
She did.
:thumbup: Equally, try finding a manual in a French vehicle in French etc etc!!! I knew someone here would have the answer 🤣🤣
Totally worked. Never seen that button before! (Well, probably have, just not registered what it might do :angelic-green: )
No more being shouted at for straightening roads out :angelic-green: :angelic-green: :angelic-green:
I did use the indicating quite a lot this morning. Not normally necessary on an empty dual carriage way! Didn’t go fast enough on the mountain road this morning to get shouted at! Bonus!
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Post by Bigjawa »
Mr. Dazzle wrote: Sat Feb 24, 2024 10:15 am Van might also have steering assist/nudge to keep you on the straight on narrow. Depending on how brave you are, you can let go of the steering wheel for quite a long time.
Tuning place I worked in had a BiTurbo that we got up to 200bhp. It was mental while it lasted.
