Search question
What can the Admins do to help, any requests for changes, updates, etc.
Eclipse
Has thanked: 37 times
Been thanked: 80 times
Search question
Post by Eclipse »
How do I search for "C Spanner" each time I try search ignores the C
Has thanked: 5449 times
Been thanked: 13084 times
Re: Search question
Place + in front of a word which must be found and - in front of a word which must not be found. Put a list of words separated by | into brackets if only one of the words must be found. Use * as a wildcard for partial matches.
Eclipse
Re: Search question
Post by Eclipse »
I tried the following and all I find is this thread or threads with spanners only in them.
"c spanner"
+c spanner
+c+spanner
c|spanner
(c|spanner)
Re: Search question
I'd expect it'll be 'search string too small' type scenario as i can't search for R for example or Y as there's too many examples, most searches require 3 or 5 characters minimum.
636mick
Has thanked: 1079 times
Been thanked: 720 times
Re: Search question
Post by 636mick »
Would Triumph C Spanner work? Or Honda, Yamaha etc.
Re: Search question
I doubt it, because C is a single letter either way.
Has thanked: 10261 times
Been thanked: 6885 times
Re: Search question
It's not a direct search engine. The software has to create the SQL on the fly from what it's given.
IIRC it's called dynamic SQL.
There's a weakness in the software, or there should be an obvious delimiter value for the space.
Re: Search question
It's the same on all forums. I'm not sure how it could be done, but I don't think anyone does it
You can search in Google via site:
https://parkinsonsnewstoday.com/forums/ ... le-engine/
But I don't know if that will help
https://www.telecomhall.net/t/how-to-se ... ogle/14895
