Just wondering how much brake fluid will be in the front brake system on the GSXR1000?
Want to flush it with Dot 5.1 but when will I know it's all been flushed through?
I expect the ABS system will hold a lot and it's located under the seat.
Ta
Brake Fluid??
- Has thanked: 10261 times
- Been thanked: 6885 times
- Tricky
- Has thanked: 2564 times
- Been thanked: 2680 times
Re: Brake Fluid??
A 500ml bottle will more than cover it-I'm probably stating the obvious here, but if you really do want to do a proper job, take the calipers off and empty them out before you start refilling and bleeding.
