Everyday is a school day...
- Been thanked: 7528 times
Random crap that I've learnt/discovered today....
The Citroen 2CV Sahara
Looks like a normal 2CV, but they had an extra engine in the boot, they could run front wheel drive, rear wheel drive or four wheel drive.
They're so rare that if you want one today you'll be needing at least £70k!
https://en.wikipedia.org/wiki/Citro%C3% ... heel_drive
- Has thanked: 9827 times
- Been thanked: 10145 times
Re: Everyday is a school day...
Funky.
But not 70k funky.
But not 70k funky.
- Has thanked: 2551 times
- Been thanked: 6244 times
Spiritual forerunner to the Mercedes A-class twin engine.
https://oppositelock.kinja.com/the-twin ... 1639259666
- Has thanked: 6188 times
- Been thanked: 5087 times
2CV with an engine in the boot?
You'll need a 'Cogolin', as built for the Var fire brigade.
iirc they (Brabus) made a twin engined Smart Roadster too.Mr. Dazzle wrote: ↑Thu Aug 20, 2020 3:51 pm Spiritual forerunner to the Mercedes A-class twin engine.
I was reading about that on the wiki page, it was so it could get into tight spaces and not need to turn around, not sure they couldn't just use reverse.. like French Tanks.
- Been thanked: 2617 times
I fancy owning a 2CV at some point, if only for the brilliantly simple design.
My old man rebuilt one for my sister as her first car, albeit a 2CV6.
Had a brand spanking new chassis and everything. He reckoned it was the only thing he'd worked on that used M7 bolts.
- Has thanked: 7817 times
- Been thanked: 2527 times
Moi aussi.
(obviously I'd be more than tempted to drop an R1150 engine into the thing....)
KungFooBob wrote: ↑Thu Aug 20, 2020 3:59 pmiirc they (Brabus) made a twin engined Smart Roadster too.Mr. Dazzle wrote: ↑Thu Aug 20, 2020 3:51 pm Spiritual forerunner to the Mercedes A-class twin engine.
There was a twin-engined Mini too (or several). (Apparantly almost impossible to drive because they couldn't get the throttles to synch very well - it was always either pulling from the front, or pushing from the rear which made the handling very odd).
I remember watching an episode of Shit Heap Challenge where they made a twin engined car... it was mentioned that they're not road legal in the UK, dunno if it's true, suppose I should google it.
Apparently it came about because the fire chief had to reverse, in the dark, several km (and guided by a guy on foot, with a torch).KungFooBob wrote: ↑Thu Aug 20, 2020 4:01 pmI was reading about that on the wiki page, it was so it could get into tight spaces and not need to turn around, not sure they couldn't just use reverse.. like French Tanks.
The Cogolin worked on one engine (and set of controls at a time) at a time.
- moth
- Has thanked: 336 times
- Been thanked: 192 times
A fortnight of ownership should be enough to persuade you otherwise. Although in your relatively vehicle free environment perhaps not.
A old neighbour, back in the 1980s, was a fan of deux cheavaux and owned several. He took me for a drive in one.
I don't scare easily, but...
Proud Tory scum since 1974.
- moth
VW Beetles used them too. IIRC, mine had some of the bodywork attached with 'em.KungFooBob wrote: ↑Thu Aug 20, 2020 4:04 pm My old man rebuilt one for my sister as her first car, albeit a 2CV6.
Mercedes F1 use MJ7 bolts. M7 is too common it would seem.
In my drawer at work I have a titanium insert they made, MJ7 on the outside, MJ5 on the inside with a 100° countersink head.
Standard sizes are for casuals.
From what I can gather, twin engines are road legal in the UK if they drive the same axle.
If not you can still drive them on the road... but with only one engine running.
Wonder how 4WD hybrids with separate electric axles deal with that.
Or any 4WD Tesla etc.
They laws may have changed, most of the stuff I was reading was conjecture on various custom car forums, I couldn't find the official government guidance.Mr. Dazzle wrote: ↑Thu Aug 20, 2020 5:13 pm Wonder how 4WD hybrids with separate electric axles deal with that.
Maybe with the advent of leccy cars they've had to change the law?
