Homda CB350 Custom
- Has thanked: 9834 times
- Been thanked: 10147 times
Homda CB350 Custom
I used to have a stock one of these as a Winter hack. Very pleasant to ride.
A reasonably tidy job. Not too hipsterish.
https://www.bikebound.com/2023/12/14/mi ... mhide=true
- Has thanked: 2407 times
- Been thanked: 3635 times
- Has thanked: 6381 times
- Been thanked: 4761 times
Re: Homda CB350 Custom
Oh lordy, pampas, avocado, some horrid blue and a sort of puke yellow. Such times!
- ChrisW
- Has thanked: 2915 times
- Been thanked: 2059 times
I kind of like it but I think the seat's too small and the headlight's prissy. I prefer it like this:
- Screenshot 2023-12-16 at 17.32.59.png (1.55 MiB) Viewed 652 times
- Has thanked: 2248 times
- Been thanked: 1242 times
- Been thanked: 2618 times
Nice enough, but the angle of the rear shock makes me twitch for some reason.
- Has thanked: 2636 times
- Been thanked: 1523 times
Unless there's some kind of rocker arm out of sight, I'm struggling to see how that shock would compress as the swing arm moves upwards.
- Has thanked: 2552 times
- Been thanked: 6257 times
It'll definitely compress/extend. It just might not do it very well But yeah the suspension is not "locked". It'll move.
- Has thanked: 310 times
- Been thanked: 568 times
I once installed a shock absorber upside down on my msx125 because the "gas bottle" (probably just a pretty bit of cast metal) needed more clearance.
Turns out the damping disappears if you do that, since the oil doesn't touch the valving. Not sure this shock will work right either.
It's certainly possible to mount a shock at that angle and for it to work well, you just need the suspension/linkages to be expecting it.
Moreover, it needs to be a pressurised shock so the oil goes to the valves.Mr. Dazzle wrote: ↑Mon Dec 18, 2023 9:21 am It's certainly possible to mount a shock at that angle and for it to work well, you just need the suspension/linkages to be expecting it.
What's really daft about that rear shock is that if you moved the swingarm mount down and the frame mount up it would work fine.
It's a bad copy of an early LC swingarm/shock layout with the geometry all to cock.
