Making a clear screen from a fibreglass template
- dern
- Has thanked: 1027 times
- Been thanked: 1797 times
My bike has a fibreglass screen as part of a rally tower but a see through version would be better. The manufacturer used to make one but they’ve been discontinued. Does anyone have an idea how I might make a transparent version of a fibreglass screen?
- Has thanked: 255 times
- Been thanked: 143 times
Re: Making a clear screen from a fibreglass template
I think you can get stuff you heat up and mould over a shape. I'll look for a YouTube.
- dern
Oh I see. That a lot easier than I imagined it would be. Perfect, thanks for posting that.
- Has thanked: 6239 times
- Been thanked: 5120 times
Although using the existing panel as a the former will result in a slightly bigger screen, so mounting holes won't align.porter_jamie wrote: ↑Wed Dec 13, 2023 9:20 am I think you can get stuff you heat up and mould over a shape. I'll look for a YouTube.
Edit: make 2, in case the first gets damaged. Actually, if you want one, there's a fair chance others might too.
- Has thanked: 2572 times
- Been thanked: 6300 times
You obviously just need a can of clear paint for the existing fibreglass.
Matt or gloss?Mr. Dazzle wrote: ↑Wed Dec 13, 2023 9:55 am You obviously just need a can of clear paint for the existing fibreglass.
- Has thanked: 6413 times
- Been thanked: 4797 times
Are you contemplating making the complete upper section? Or modifying it with a clear insert/wraparound and using some of the existing part as support/frame?
Seems the decision is, acrylic or plexi. Both have advantages. I'm assuming you take the panel off you want to replicate and mould over it and then spend hours afterwards trimming with the dremel to get it to fit then bang the holes.in.Horse wrote: ↑Wed Dec 13, 2023 9:43 amAlthough using the existing panel as a the former will result in a slightly bigger screen, so mounting holes won't align.porter_jamie wrote: ↑Wed Dec 13, 2023 9:20 am I think you can get stuff you heat up and mould over a shape. I'll look for a YouTube.
I wonder how much the sheets are? Hopefully in the 10 or 20 quid range not 100 to 200...
I'd be tempted to take the panel off, wrap it in something like clingfilm and use an aerosol foam filler to make a former then at least the curvature should be OK. Also try and take a sheet of thicker plastic like builders sheet and try and copy the shape (wet the original screen, slap it on and trim it) so you get an idea of what the starting flat acrylic/plexi looks like.porter_jamie wrote: ↑Wed Dec 13, 2023 12:05 pmSeems the decision is, acrylic or plexi. Both have advantages. I'm assuming you take the panel off you want to replicate and mould over it and then spend hours afterwards trimming with the dremel to get it to fit then bang the holes.in.Horse wrote: ↑Wed Dec 13, 2023 9:43 amAlthough using the existing panel as a the former will result in a slightly bigger screen, so mounting holes won't align.porter_jamie wrote: ↑Wed Dec 13, 2023 9:20 am I think you can get stuff you heat up and mould over a shape. I'll look for a YouTube.
(In reality I'd probably cut a section out of the original and insert the clear stuff somehow ).
The inside of the new one will be the right shape, but it won't matter a toss, I'm sure
- dern
The complete upper screen. I don't want to modify the original.Count Steer wrote: ↑Wed Dec 13, 2023 10:27 am Are you contemplating making the complete upper section? Or modifying it with a clear insert/wraparound and using some of the existing part as support/frame?
I've measured the one that's on the bike and I just need a piece 500mm by 500mm. There are no compound curves to speak of so I should just be able to make a cardboard template, make two folds and a lip at the top and it should be good. I'm planning on covering the headlights too as they're inset and this should give them more protection. If I'm wrong about the lights I'll either make a cut out or see if I can form that section out a bit.
I just need to do some research on how thick it needs to be but I'm guessing that 3mm will be plenty.
Matt, gloss would make too much glare FFSHorse wrote: ↑Wed Dec 13, 2023 9:58 amMatt or gloss?Mr. Dazzle wrote: ↑Wed Dec 13, 2023 9:55 am You obviously just need a can of clear paint for the existing fibreglass.
Dunno what material this guys using but it popped up today and may be of interest.dern wrote: ↑Wed Dec 13, 2023 2:07 pmThe complete upper screen. I don't want to modify the original.Count Steer wrote: ↑Wed Dec 13, 2023 10:27 am Are you contemplating making the complete upper section? Or modifying it with a clear insert/wraparound and using some of the existing part as support/frame?
- dern
That's cool, thanks. I had to do the same thing on the rsv I recently sold but as it was a flat piece I didn't have to do any of the shaping. I wish our oven was big enough as that makes it look like a piece of piss.Count Steer wrote: ↑Thu Dec 14, 2023 3:40 pm
Know anyone in catering (who doesn't mind their produce having a piquant hint of plastic)?
