Front wheel not centred
Has thanked: 2317 times
Been thanked: 1821 times
Post by Jody »
Hi all
Lapiere zesty 514 2013
Wheel is badged as Shimano Deore XT
No idea how I haven't noticed this before but here we are!....
The front wheel is not central in the forks, it's off to the left (disc side) by 3-4mm
What can cause this and how do I fix it?
Re: Front wheel not centred
In simple terms, it's called 'dishing' basically you'd loosen the spokes on one side, tighten the ones on the other side.. That essentially moves the hub over to the left/right accordingly.
It's a bit of a dark art so i'd be asking the local shop to do so personally.
