Cycle chain cleaning
- formula400
- Has thanked: 444 times
- Been thanked: 863 times
Last night I spotted a small patch of rust on the out side of 2 chain links. What’s the best way to remove??? A ge yak wire brush????
Then what’s the best product for cleaning the chain???
I’ve just got some Silca Synergetic Drip Lube to oil it.
I’d like to wax at some point. But until then I need to clean the chain and cogs. (It’s not that dirty)
Cheers
Cheers
CBR650r
- Has thanked: 1829 times
- Been thanked: 1469 times
Re: Cycle chain cleaning
apparently there is a whole sub culture of waxing using Plutoline . Apparently it elevates you you a different level of cycling chain care
- Has thanked: 5449 times
- Been thanked: 13085 times
- formula400
Yeah, it’s quite involved I think. Striping all the grease and waxing.
CBR650r
- formula400
Well i've had my Slayer for 11 months now and used it more than most riders, wet, dry, muddy, musty... chain still fine..
- formula400
Correct. Pretty much every ride unless dusty. Wash bike, dry chain, lube with GT85, put away.formula400 wrote: ↑Thu Sep 28, 2023 1:49 pm
Do you clean and lube it with that after every ride???
I tend to use whatever lube I have handy - GT 85 if nothing else , I am. even not adverse to using Halfords own brands. Peatys stuff , and Finish Line etc seem to be crazily expensive.
Re Weeksy - he is special and does have particular cleaning regimes. However what he does will help chain longevity. The was someone on STW who takes their chain off the bike after each ride to clean and lube it.
Mine gets done if the bike is caked in shit and then given a good clean - or in the summer if it looks dry.
Putoline is way too much faff1
As I'm washing the rest of the bike the chain and cassette get a going over with muck off, and then in the stand I'll wipe the chain down and lube with whatever cheap oil I've got at the time.
