Bodgeneering an 18V drill & battery
- Been thanked: 2612 times
The drill. A Hitachi/Hikoki found in a skip. I want to use it with my Makita LXT batteries.
Reduce the Hitachi battery from this:
to this:
Add one of these:
That's an adapter bought via Ebay, usually about £10. The wires as supplied are unterminated, I prefer uninsulated crimps as I perceive them to be better than the usual red/blue/yellow preinsulated ones.
to this:
Add one of these:
Re: Bodgeneering an 18V drill & battery
The drill body has to be split, sometimes the chuck and nose ring don't have to come off, this one does. The screw pictured is a left hand thread and stops the chuck unscrewing when the drill is used in reverse. My method for removing chucks is an allen key and a hammer.
Split and with the adapter wiring fitted. Some you can fit without splitting the drill, sometimes it's easier to split the thing:
The terminals on this one can be pushed on and then nipped down:
Reassembled, waiting for the hot glue:
Hot glued and with battery attached:
I'll test it for a month or so in normal use and then shift it on.
- Has thanked: 9819 times
- Been thanked: 10144 times
Top recycling and ingenuity. Bodgeneering is also a cool word.
- DefTrap
- Has thanked: 2259 times
- Been thanked: 2190 times
Yeah I was watching a YouTube where a guy did exactly that (the web now knows that I'm a shed-drill-messer-geek and is spamming me furiously ) and it seemed a good way of getting some more life out of these perfectly serviceable tool bodies.
A really trivial niggle is that the variety of cordless tools only really blossomed when Li-ion became the standard power supply. Previous to that it's mostly drills, saws and bizarre specialist things.
If anyone wants this with or without the adapter then message me.
