Turning right is dangerous
- Has thanked: 1373 times
- Been thanked: 253 times
Turning right is blooming dangerous — at least if you’re a cyclist:
https://road.cc/content/news/turning-ri ... sts-303693
Evidently, it’s time to give up cycling (too bloody dangerous) and instead stick to motorcycling.
- Has thanked: 484 times
- Been thanked: 1427 times
Re: Turning right is dangerous
For a long time this is what I have believed. On major roads I don't use the official method if I am cycling. Instead I pull in to the nearside kerb and wait until the road is clear in both directions.
I must say even on the (motor)cycle, I try to avoid turning right off relatively fast single carriageways. It only takes someone following to be fiddling with their mobile phone to end in disaster. There's usually an alternative that doesn't carry the same risk.
- Has thanked: 6375 times
- Been thanked: 4746 times
Didn't learn this on a bike but it may apply. When waiting to turn right, don't turn the wheel ready for the turn because when aforesaid numpty fiddling with phone rear ends you, you get shoved into the oncoming traffic.iansoady wrote: ↑Thu Sep 07, 2023 10:05 am I must say even on the (motor)cycle, I try to avoid turning right off relatively fast single carriageways. It only takes someone following to be fiddling with their mobile phone to end in disaster. There's usually an alternative that doesn't carry the same risk.
- Has thanked: 7810 times
- Been thanked: 2527 times
I've been hit from behind while waiting to turn right on a fast-ish A-road. The bike, a K1200R was hit so hard the swingarm bent, trapping the drive-shaft so tight the bike couldn't be pushed. They had to lift the rear wheel off the deck to get it into the recovery van.iansoady wrote: ↑Thu Sep 07, 2023 10:05 am I must say even on the (motor)cycle, I try to avoid turning right off relatively fast single carriageways. It only takes someone following to be fiddling with their mobile phone to end in disaster. There's usually an alternative that doesn't carry the same risk.
For some reason I am still completely befuddled by, the cuddly-wuddly-beary-boo wasn't even prosecuted by the police for anything at all. Made the insurance claim harder.
I received concussion and lost about 20 minutes - one moment I was on the bike watching for a gap in the oncoming, the next I'm starting to sit up with the ambulance crew in attendance and a copper asking me damn-fool questions about why the hazard lights on the bike were on. (I think I'd flicked them on because I saw a car behind me approaching, about 100 yrds back and realised I was under a tree shadow).
- Has thanked: 2635 times
- Been thanked: 1523 times
I might have mentioned itCount Steer wrote: ↑Thu Sep 07, 2023 10:09 amDidn't learn this on a bike but it may apply. When waiting to turn right, don't turn the wheel ready for the turn because when aforesaid numpty fiddling with phone rear ends you, you get shoved into the oncoming traffic.iansoady wrote: ↑Thu Sep 07, 2023 10:05 am I must say even on the (motor)cycle, I try to avoid turning right off relatively fast single carriageways. It only takes someone following to be fiddling with their mobile phone to end in disaster. There's usually an alternative that doesn't carry the same risk.
It was a Jackie Stewart driving tip years ago. That's where I heard it.
PS... how did these collisions happen BEFORE mobile phones?? Just asking
It was just an example...... I'm sure we can all think of lots of other attention-diverting situations.The Spin Doctor wrote: ↑Thu Sep 07, 2023 9:10 pm
- Has thanked: 6186 times
- Been thanked: 5087 times
Are triple-edged swords available? Double doesn't seem sufficient.iansoady wrote: ↑Fri Sep 08, 2023 10:11 amIt was just an example...... I'm sure we can all think of lots of other attention-diverting situations.The Spin Doctor wrote: ↑Thu Sep 07, 2023 9:10 pm
Modern cars are much easier to drive. EFI, power steering, etc. So potentially allowing more concentration outside of the vehicle. So we invent new distractions (which actually means an additional choice for concentration). And, of course, roads are typically busier too.
But it's also the go-to knee-jerk conclusion to explain collisions and near misses.
In a study of motorcycle fatals in London a couple of years ago, out of 50 deaths, just ONE had mobile phone use as a contributing factor... that was the same number of biker deaths caused by 'medical emergency at the wheel'.
What's the next bit of research from the "school of the bloody obvious"?Hot_Air wrote: ↑Wed Sep 06, 2023 9:30 pm Turning right is blooming dangerous — at least if you’re a cyclist:
The issue really being that for many, many, probably lovely people... the bloody obvious... isn't.
- Has thanked: 229 times
- Been thanked: 575 times
That applies in the car too. Keep pointing straight till you move off.Count Steer wrote: ↑Thu Sep 07, 2023 10:09 amDidn't learn this on a bike but it may apply. When waiting to turn right, don't turn the wheel ready for the turn because when aforesaid numpty fiddling with phone rear ends you, you get shoved into the oncoming traffic.iansoady wrote: ↑Thu Sep 07, 2023 10:05 am I must say even on the (motor)cycle, I try to avoid turning right off relatively fast single carriageways. It only takes someone following to be fiddling with their mobile phone to end in disaster. There's usually an alternative that doesn't carry the same risk.
I’ve had a hire car for the last 2 days - an MG HS SUV thingy. Driving along, too hot, want to “make it less hot”. Large central screen, small icon on the far side, aim for it, miss and get something else, stab again to get back to “home”, eventually get to the heating / vent bit, repeat etc etc. All trying to keep focus on the road. We have an Up GTI at home. Big knobs, findable if I was blind, seats ditto, fan yep.Horse wrote: ↑Fri Sep 08, 2023 10:23 amAre triple-edged swords available? Double doesn't seem sufficient.iansoady wrote: ↑Fri Sep 08, 2023 10:11 amIt was just an example...... I'm sure we can all think of lots of other attention-diverting situations.The Spin Doctor wrote: ↑Thu Sep 07, 2023 9:10 pm
Most modern cars seem to be variations of that- we can do it on a screen, so we will. Forget mobile phones, it’s the car, not even the driver, that’s the problem.
And another thing…MG HS- rear view is appalling. I can see headrests and the lower edge of the screen. Can’t see the car behind even at night even with its lights on. Terrible design. Bah.
Some manufacturers have stated that they will move back to 'hard' controls.
I mentioned that to a mate who was doing a PhD.Rockburner wrote: ↑Fri Sep 08, 2023 1:00 pmWhat's the next bit of research from the "school of the bloody obvious"?Hot_Air wrote: ↑Wed Sep 06, 2023 9:30 pm Turning right is blooming dangerous — at least if you’re a cyclist:
He replied that until someone did the research, it could only fall into the 'bleedin obvious' category and that might be wrong.
Like, for example, hi-vis and headlamps to stop SMIDSYs. Obvious, innit?
Yup, plenty of research through the years.
Perhaps the most valuable one being an old TRRL project that did a 'before and after' study, the 'after' being bikes with conspicuity aids.
Unfortunately, trials participants saw all of the control 'inconspicuous' bikes
The most valuable new idea comes from the UK and suggests drivers 'look, see, but forget again' due to limited visual memory - we can only remember about 5-6 objects at the same time. And it's last in, first out... so if the cycle or motorcycle is actually the FIRST thing the driver spotted, and if there's a lot of 'stuff' going on, then there's a good chance the fact that the driver saw it will go out of working memory...
...as far as the driver is concerned "it appeared from nowhere".
I've had riders say "but look at that headlamp - he's 1/4 mile away and you can see him!"The Spin Doctor wrote: ↑Mon Sep 11, 2023 9:05 am The most valuable new idea comes from the UK and suggests drivers 'look, see, but forget again' due to limited visual memory - we can only remember about 5-6 objects at the same time.
There's also the 'where do drivers look?' work (Labbatt? Langham?) which suggested experienced drivers look only where they think approaching vehicles will be (and only look for 0.4s).
Add to that other work which found that riders are often going faster than other traffic (so may be outside of that 'where' zone). And the 'time to arrival illusion'.
There's research which also tries to discover what conspicuity aids work at long distance... headlight modulators work at 1000 ft plus according to one US study... as I commented at the time - "we don't collide with cars over 1000 feet away". It's the last 75 or so that matters.Horse wrote: ↑Mon Sep 11, 2023 9:37 am
