Powder coat or paint wheels?
dern
Has thanked: 1027 times
Been thanked: 1797 times
Post by dern »
I have some wheels that are pretty scuffed up and I want to change their colour (I think). Is paint or powder coat better for longevity?
Thanks
Has thanked: 5468 times
Been thanked: 13167 times
Re: Powder coat or paint wheels?
Powder. You should've asked at weekend. We had our zx6 wheels done a year or so ago. They look brand new
dern
Post by dern »
I hadn't thought about it then to be honest. I was on the way home and I started to think about putting the honda I had at Pembrey back on the road and what it would need.
Has thanked: 10336 times
Been thanked: 6915 times
Rear of bike up on stand. Mask off the tyre.
Put into gear. Start engine. Rattle can onto wheel.
They look like new :)
Has thanked: 2415 times
Been thanked: 3659 times
Powder is definitely more hard wearing than paint, but it does need a bit more prep (removing bearings etc.) The powder coat guy I use in Shropshire has a 5 step process that I'm not sure all powder coaters use:
1. Chemically strip then vapour blast wheels
2. Mask up or plug all threads and bearing surfaces
3. Put wheels in oven for approx 30 minutes to de-gas; if you don't do this you run the risk of pinholes from escaping gas.
4. Apply primer and bake in oven
5. Apply top coat and bake in oven
In particular a lot of the cheaper outfits omit steps 3 and 4 and may use bead blasting rather than vapour blast.
dern
Post by dern »
mangocrazy wrote: Sun Aug 13, 2023 3:28 pm Powder is definitely more hard wearing than paint, but it does need a bit more prep (removing bearings etc.) The powder coat guy I use in Shropshire has a 5 step process that I'm not sure all powder coaters use:
I spoke to a guy who was exhibiting at a local car show and was talking to him about doing a frame I have too. I'll talk to him again about the wheels and check the process he uses so this is really useful, thanks.
There might also be a final clear coat that's applied; I'd need to check with Andy on that.
Has thanked: 609 times
Been thanked: 4133 times
Have a look at someone's work before spending money, some powder coaters like a thick coating.
Has thanked: 2945 times
Been thanked: 2075 times
Definitely powder coat if it was me, but then I've got somewhere I've used a few times & trust. Find somewhere busy with lots of good reviews/feedback.
wheelnut
Has thanked: 911 times
Been thanked: 1010 times
Post by wheelnut »
Last bike I had powder coated was a 1982 DT50MX*, in about 1986. Did the swingarm and the fame in red.
*technically a DT60MX - it had a big bore kit. :D
Bloke near Trickys did mine. Well, I dropped bike at my mechanic mate at MSG racing and he sorted it all through ilthe bloke
