Puig Screen - how can I cut it down?
- Has thanked: 1832 times
- Been thanked: 1469 times
I have a Puig adjustable screen for the Diavel. It’s the size of a barn door.
They also do it in Sports size - which is about 30% smaller. From a visual point of view - and possibly practically , it could work better.
Is there anyway to cut acrylic so it doesn’t look rubbish?
- Has thanked: 7829 times
- Been thanked: 2532 times
Re: Puig Screen - how can I cut it down?
Very gently with a Dremel, then file/sand the edge round and clean with "not very rough" paper.
- Has thanked: 4372 times
- Been thanked: 2863 times
- dern
- Has thanked: 1018 times
- Been thanked: 1786 times
I recently cut down a piece of lexan for a replacement gauge cluster 'window' with a dremel to do the initial cutting and then a standard bench grinder to get to a smoother start point you could polish from. The bench grinder worked amazingly well and there was no grabbing and provided you took it steady there was far less melting than with the dremel as the grinding wheel didn't get anywhere near as hot.
From there you'll want to wet and dry sand it with a block I imagine but I didn't get to do this so I'm remembering this from school when we formed and polished acrylic sheet but that was a very very long time ago.
The trick with all of it is not to get too much heat in to the piece and protect the surface with masking tape.
Which is a very good answer - but I don't really like the touring screen and don't want to blow more cash on something that may or may not work.
I have the DP Touring screen as well - but it's not really easy on the eye!
- Has thanked: 1044 times
- Been thanked: 362 times
This chap has done it on his HD - I remembered shade tree surgeon doing it to one of his gold wings.
- Has thanked: 1353 times
- Been thanked: 1733 times
Pretty sure they run a blowtorch over the cut edges of perspex to smooth and clear them up in signmakers.
They'll be something about it on Youtube no doubt.
Looking at those you tubes it’s doable. But matey boy just had to do the top - I would need to do three sides which equals three curves.
- Has thanked: 1373 times
- Been thanked: 253 times
Are bigger screens always quieter than smaller ones?
Alternatively, you may be better off with one of MRA’s screens that aren’t barn-door-sized (e.g. an MRA Racing Screen).
- Cousin Jack
- Has thanked: 2563 times
- Been thanked: 2295 times
Get an MRA screen with a spoiler thing on the top. That little bit at the top does actually work!
They are not easy on the eye ...
- Has thanked: 1754 times
- Been thanked: 2095 times
Puig dark smoke sports screen is the answer.
