NGK plug caps
NGK plug caps
I need a pair for my in-progress Grumph but they're almost totally unavailable - Green Spark Plug and others show no stock. I eventually found a supplier. Anybody else had difficulty with items like these?
- Has thanked: 7852 times
- Been thanked: 2555 times
Re: NGK plug caps
Not yet....
I'm considering replacing the cap on the JAPton soon - didn't realise there was a limited supply....
- Has thanked: 609 times
- Been thanked: 4133 times
Re: NGK plug caps
For ferrule ended plugs? or threaded ends?Le_Fromage_Grande wrote: ↑Tue Aug 08, 2023 11:30 am Of you want right angle short ones I've probably got some
Re: NGK plug caps
Threaded I think, whatever is standard on a 1982 GPz1100Rockburner wrote: ↑Tue Aug 08, 2023 11:56 amFor ferrule ended plugs? or threaded ends?Le_Fromage_Grande wrote: ↑Tue Aug 08, 2023 11:30 am Of you want right angle short ones I've probably got some
- MrLongbeard
- Has thanked: 604 times
- Been thanked: 2470 times
Re: NGK plug caps
Buy this, there's sure to be some in the mix
https://www.facebook.com/marketplace/it ... 112l%22%7D
- Has thanked: 2572 times
- Been thanked: 6300 times
Re: NGK plug caps
I'd never even seen a threaded end plug until I got the Bonnie.Le_Fromage_Grande wrote: ↑Tue Aug 08, 2023 3:21 pmThreaded I think, whatever is standard on a 1982 GPz1100Rockburner wrote: ↑Tue Aug 08, 2023 11:56 amFor ferrule ended plugs? or threaded ends?Le_Fromage_Grande wrote: ↑Tue Aug 08, 2023 11:30 am Of you want right angle short ones I've probably got some
Or maybe I'd never even seen a ferrule ended one, I can't remember which way around it was
In either case, you can just spin the end off the plug. Or spin it on I suppose.
