Baja no tube pinch tyre tool
- Has thanked: 15947 times
- Been thanked: 10243 times
The simple ideas are always the best, but sadly, often the most expensive too!
https://www.bajanopinch.com/
- dern
- Has thanked: 1016 times
- Been thanked: 1766 times
Re: Baja no tube pinch tyre tool
That's pretty neat. I bet that you could make something like that pretty easily.
- DefTrap
- Has thanked: 2259 times
- Been thanked: 2190 times
Does this work on tubeless as well? Only because they always seem waaaay stiffer than tubed.
- ChrisW
- Has thanked: 2903 times
- Been thanked: 2052 times
Wondered that too, I had a look at their site & they specifically say it's not for use on tubeless but only on safety grounds. As for whether it'd work at all I bet a longer lever would help it along if it was having difficulty.
- DefTrap
Yeah because with tubed tyres surely a bog standard lever is normally sufficient right?
It looks much easier way to put a tyre on, bit also, a lot less rim damaging than levering against. Not sure why its touted as being for tubes only?
- Been thanked: 7526 times
It works out at about £120.
My local fitter does tyres for about £10 a wheel.
So it pays for it's self after 12 tyres changes.
I find it easier to buy a new motorcycle when the tyres wear out.
