That annoying moment when....
SSS
Has thanked: 46 times
Been thanked: 65 times
Post by SSS »
When you go to raise the front of the bike with your paddock stand and you get handful of pins, and you dont have the one you need......
Cant get the verniers into the area, so some website file i found says its a 21mm pin. Demon Tweeks = ordered.
To be fair my own bloody fault for not actually checking....
So much for tonights fettle on the 'cat.
Has thanked: 10336 times
Been thanked: 6915 times
Re: That annoying moment when....
Use a trolley jack under the downpipes :)
SSS
Post by SSS »
It might come to that 🤣. I have my trolley Jack at the ready…
Has thanked: 541 times
Been thanked: 7594 times
You need an ABBA stand and the front lift kit.
SSS
Post by SSS »
I’ve got a Warrior Front Paddock Stand. Just need the correct sized pin now.
Other than that the trolley Jack. And I’ve been having a good look at the rafters 😁
Has thanked: 5467 times
Been thanked: 13167 times
18mm pin and gaffer tape
SSS
Post by SSS »
Found a rawl anchor bolt of all things which has same diameter and works. It'll do till the real pukka one comes :D
