Oil Filter Change?
- Has thanked: 10336 times
- Been thanked: 6915 times
Oil Filter Change?
I've always just tightened by hand, but the manual says 2 FULL turns.
Wow. That seems excessive.
Maybe that's just the OEM ones. My local shop always used Hi Flow filters.
That's what I bought yesterday.
Waddya reckon?
Waddya reckon?
- Has thanked: 4383 times
- Been thanked: 2867 times
Re: Oil Filter Change?
My GSXS is exactly the same. 2 full turns or 20NM. Which seems well OTT to me. I've no idea how tight mine are as both services so far were done by the dealer. If I was doing the service I'd stick to hand tight as I've seen what happens when they are over tightened. I've never had a filter come loose.
I did hand tight. About one and quarter turn. Last bit was very tight.
Saw vids on Hiflo filters say one turn, ish.
- Has thanked: 609 times
- Been thanked: 4133 times
Suzuki like a tight oil filter, I suspect it goes back to the 1985 GSXR750 which had a nasty habit of the oil filter coming undone, I used to put a jubilee clip round the oil filter to stop it coming undone on my one.
- wull
- Has thanked: 884 times
- Been thanked: 1555 times
You’ll be fine with tightening as tight as you can by hand, Fresh oil smeared on the seal as well. Just check it for any leaks after a few uses.
If you were paranoid about it you could either use the jubilee clip method or use Lockwire which iirc the HiFlo racing filters come with the end pre-drilled for accepting Lockwire.
- DefTrap
- Has thanked: 2276 times
- Been thanked: 2199 times
Hand tight, it'll always seem like it tightened up some more if you try to take it off. I must have changed a bazillion oil filters over the years, all tightened by hand (I don't have anything else), and all of them have required a strap / chain to get them off for the next change.
- wull
Exactly this, with my job I do an obscene amount of filters from oil to hydraulic and I always tighten them by hand, next time round they are a nightmare to remove. The strap I have is awesome though.DefTrap wrote: ↑Thu Jun 29, 2023 3:13 pm Hand tight, it'll always seem like it tightened up some more if you try to take it off. I must have changed a bazillion oil filters over the years, all tightened by hand (I don't have anything else), and all of them have required a strap / chain to get them off for the next change.
Yeah. Me too. Was worried by what the manual says.DefTrap wrote: ↑Thu Jun 29, 2023 3:13 pm Hand tight, it'll always seem like it tightened up some more if you try to take it off. I must have changed a bazillion oil filters over the years, all tightened by hand (I don't have anything else), and all of them have required a strap / chain to get them off for the next change.
RTFM? Nah
- Has thanked: 2572 times
- Been thanked: 6300 times
- wull
Mr. Dazzle wrote: ↑Thu Jun 29, 2023 6:29 pmWhat you do in the privacy of your own home is your business fella.
