Chain Cleaning
Chain Cleaning
What do you use to clean your chain, do you use a liquid chain cleaner, if so what, have you checked to see if it damages O rings?
I feel I should clean my chain, but I've no idea what to do it with, I know WD40 knackers O rings (they go brittle and crumbly) so I was wondering what to use, in the past I've used clean cheap engine oil and a brush as it shouldn't do any damage, but it's a bit messy.
- Has thanked: 5453 times
- Been thanked: 13097 times
- Has thanked: 2249 times
- Been thanked: 1242 times
Re: Chain Cleaning
Always used paraffin (or I did when I could be arsed, just let the Scottoiler do its thing these days!)
- Has thanked: 2552 times
- Been thanked: 6260 times
Re: Chain Cleaning
Me too, with one of those 3 sided brushes.v8-powered wrote: ↑Tue Jun 13, 2023 2:16 pm Always used paraffin (or I did when I could be arsed, just let the Scottoiler do its thing these days!)
- wull
- Has thanked: 881 times
- Been thanked: 1551 times
Re: Chain Cleaning
I swear by Motul C1 chain clean and C2 chain lube, I’m a chain whore and have tried them all, this for is by far the best.
Re: Chain Cleaning
Feck me, that's cleaner than a new chain, does the can say what's in it?
- dern
- Has thanked: 1017 times
- Been thanked: 1780 times
- ChrisW
- Has thanked: 2915 times
- Been thanked: 2060 times
Re: Chain Cleaning
GT85 to clean - neither this nor WD40 harm O / X rings but I prefer GT85 because it smells nicer. I don't lube except for wet weather, which means less frequent cleaning.
Not in Wull's league, no even close, but this is a fairly cheap OEM chain at nearly 12,000 miles:
- Has thanked: 4364 times
- Been thanked: 2853 times
Re: Chain Cleaning
Used to use paraffin. Now I'm using this.
https://wd40.co.uk/product/motorbike-chain-cleaner/
This was a spray, leave for 30 secs and wipe off. It'd be better if I used a chain brush which I will be doing this week before I go away for the weekend.
Bikesocial tested WD and Paraffin on o rings and they seemed fine.
Re: Chain Cleaning
So far the cheapest degreaser is looking like petrol, which is a bit flammable, followed by Gunk at £10ish for 5 litres on Amazon
Re: Chain Cleaning
I seem to recall from the Bikesocial test petrol not being good for o-rings. Paraffin is cheap and fine with them.Le_Fromage_Grande wrote: ↑Tue Jun 13, 2023 3:22 pm So far the cheapest degreaser is looking like petrol, which is a bit flammable, followed by Gunk at £10ish for 5 litres on Amazon
- Bigyin
- Has thanked: 1412 times
- Been thanked: 2680 times
Re: Chain Cleaning
I use the Motul chain cleaner and a 3 sided brush then Motul Road chain lube although I do have some Motul Race lube as well.
But of a change from years ago as a yoof when I kept just lobbing lube on top of lube and grime and wondered why chains didn’t last as long as other people’s
- Has thanked: 10274 times
- Been thanked: 6891 times
Re: Chain Cleaning
I've ever cleaned chain in my life.
And last time I had to replace a chain was on my CBR600 in early 90s. About 25k IIRC.
Always kept my bikes about 2 years since then
But my first GSXR1000 did 29k. They all had a harder life than most.
- ChrisW
Re: Chain Cleaning
I never cleaned a chain till recently. I only ever replaced 1 chain as I always sold the bikes before the chains were knackered.
Re: Chain Cleaning
Actually I'm going to clarify that. I never cleaned a chain till I got old and sad. There's a part of me that laughs like a drain while I sit there cleaning the bloody thing, metaphorically throwing empty beer cans at the middle aged tosspot cleaning chains rather than riding the bloody thing!
- Has thanked: 261 times
- Been thanked: 1266 times
- Has thanked: 221 times
- Been thanked: 878 times
Re: Chain Cleaning
Always just used heating oil, because there always seems to be a huge tankful of it nearby.
I put the chain on my Bandit in 2006. Its about half worn.
- Has thanked: 9836 times
- Been thanked: 10149 times
Re: Chain Cleaning
A rag.
