M5 tap.... with tool/handle... where from ?
- Has thanked: 5467 times
- Been thanked: 13167 times
I bought a cheap ebay tap set for about £6, which worked well enough, but is now worn and crap after 3-4 uses
So want to buy a decent set this time..
- MrLongbeard
- Has thanked: 604 times
- Been thanked: 2470 times
Re: M5 tap.... with tool/handle... where from ?
I'd be looking at Cromwell or RS components for decent kit.
- Has thanked: 7852 times
- Been thanked: 2555 times
- Has thanked: 255 times
- Been thanked: 143 times
You need to make sure it's high speed steel not carbon. Put the link up before you press buy so we can look
Dormer stuff is good. Don't buy shite as it will snap off and ruin your expensive what ever you were working on.
- Has thanked: 2572 times
- Been thanked: 6300 times
We use taps a lot at work, mostly for cleaning threads but also for cutting new threads. We buy them from Wurth, they must be pretty good because I haven't broken one for months
https://eshop.wurth.co.uk/is-bin/INTERS ... Name=SR007
https://www.tracytools.com/products/
yeahIknowsRockburner wrote: ↑Wed May 24, 2023 8:20 pmhttps://www.tracytools.com/products/
Just think the name is amusing every time I hear it.
- Has thanked: 65 times
- Been thanked: 1235 times
Ffs this place is going to the dogs!
Strensham, Micheal Wood are closest to you!
I'm here to help
I'm here to help
- Has thanked: 218 times
- Been thanked: 689 times
