Top tips for “get you home” repairs.
- Has thanked: 262 times
- Been thanked: 1278 times
- Trinity765
- Has thanked: 2444 times
- Been thanked: 2399 times
- Has thanked: 541 times
- Been thanked: 7594 times
- DefTrap
- Has thanked: 2276 times
- Been thanked: 2199 times
Re: Top tips for “get you home” repairs.
I'm over 40k miles into a JBWeld get-you-home fix on the moighty 406.
- Has thanked: 9901 times
- Been thanked: 10212 times
It's a cracker.
- Has thanked: 499 times
- Been thanked: 1447 times
- Has thanked: 164 times
- Been thanked: 308 times
I thought the old one was cooks matches and paper clips for distributor arms, but that doesn't do much for modern vehicles.
Now it's more alligator clips, a reel of cable and low-temp solder connectors, plus a small cooks blowtorch for said connectors.
- Has thanked: 2572 times
- Been thanked: 6300 times
Carbon fibre is nought but JB weld with fancy string in it anyway.
- DefTrap
TBF this was JBWeld splodged into a leaking core plug (accessed by feel only down the back of the motor and firewall), which I fully expected to fail fairly immediately given the likelihood of access causing a poor repair and also numerous subsequent heat cycles.Mr. Dazzle wrote: ↑Wed May 24, 2023 1:04 pm
My brother did exactly the same fix on a Ford Sierra, lasted about a week
So there you are, the spectrum of success is quite wide.
- Has thanked: 2415 times
- Been thanked: 3659 times
I've used epoxy putty to good effect in the past. When screwing into floorboards I came across a 'hard bit' and instead of backing off and thinking about it I persisted and screwed into a central heating pipe. Epoxy putty came to the rescue there and the 'fix' has lasted well over 20 years. Apparently you can get putty that's specific to the task in hand - I just used one size fits all stuff.
https://jenolite.com/metal-epoxy-putty/
- Has thanked: 65 times
- Been thanked: 1235 times
Bodgers!DefTrap wrote: ↑Wed May 24, 2023 2:12 pmTBF this was JBWeld splodged into a leaking core plug (accessed by feel only down the back of the motor and firewall), which I fully expected to fail fairly immediately given the likelihood of access causing a poor repair and also numerous subsequent heat cycles.Mr. Dazzle wrote: ↑Wed May 24, 2023 1:04 pm
Many moons ago I owned a s2 LR that blew the rear head core plug. Went to work, punched out a 4 mm thick ally disc, a bit bigger than the hole, carefully dished it (let's just say it involved a ball pein ok). It was then offered up into place with a broom handle and lightly tapped for seating, then the dished bit was given a decent thwack to spread it. Ne'er a days problem after! There was also the ti Clevis pin mod as well!
Tim Fry eat your heart out!
- Has thanked: 1525 times
- Been thanked: 1433 times
I remember a bloke who holed a piston in the Mini he had up for sale with a buyer due. Popped the head off & epoxied a piece of 1/8in aluminum plate to the top of the piston. Slapped it back together, & fired it up. It ran. Shut it off.
Buyer shows up & bought it.
Buyer heads off in his new car. Only got a few hundred yards before a horrendous noise indicated all was not well. Managed to limp it back to the sellers house & got his money back.
The plate had come loose & turned 90deg in the cylinder.
We had the piston & very bent plate sitting on the shelf of horrors in the college engineering dept at Cambs
- Has thanked: 10336 times
- Been thanked: 6915 times
I saw a bodge where someone dropped a bolt through the hole and stuck a nut on the inside.ZRX61 wrote: ↑Mon May 29, 2023 1:08 am I remember a bloke who holed a piston in the Mini he had up for sale with a buyer due. Popped the head off & epoxied a piece of 1/8in aluminum plate to the top of the piston. Slapped it back together, & fired it up. It ran. Shut it off.
Then ground the bolt head flush with piston head
A village idiot I knew bought an H2 that was only running on two pots. It had spark, but the exhaust smelled *odd*
Turns out the smell was from the tennis ball stuck on the middle rod melting when that cylinder fired. Apparently this was a fairly common trick on 250cc cylinders. Someone recently told me he'd come across the same *fix* on a Suzuki 500T.
