Diesel Corsa. Of course its broken..
chillitt
Has thanked: 144 times
Been thanked: 164 times
Post by chillitt »
Given that the Transit Is slowly decaying to the point even I cant put up with it, and another one may be along in a few months, I have been lent a little Corsa. No, its no bloody use when I need a Transit sized thing, and no, its not something I really want, but It will keep me going for a bit. Anyway, on top of that, it wont start without easy start. Fuel pump works well, fuel filter works fine. So Im thinking there is a fuel shut off on the injector pump somewhere thats not performing properly. Does anyone know of a decent forum that isnt over run with chavvy little tosspots pretending this little rollerskate is a race car?
Been thanked: 7530 times
Re: Diesel Corsa. Of course its broken..
Glowplugs?
chillitt
Post by chillitt »
One is broken, but I cant see that making much odds. Apparently they only come on when its below 0 (not 100% sure on that..) As soon as it catches with easystart it runs nice and smooth, I'd expect it to be a bit lumpy if it was glowplugs. I need to check for error codes so need to find software for the laptop or a reader.
How old is it?
If it's an old one and direct injection it could be air getting in the system either from a leaky injector union or a dodgy priming bulb, etc..
chillitt
Post by chillitt »
Its a 1.4 Ecotek. 2004. If it was the old Isuzu 1.7 I might have more idea..
Sure it's not a 1.3?
I think it's a FIAT common rail.
CR diesels are far too complicated.
chillitt
Post by chillitt »
1888 wrote: Sat Aug 01, 2020 7:28 pm When you say wont start without easy start do you mean each time or just first thing in the morning starts?
easy start every time
chillitt
Post by chillitt »
KungFooBob wrote: Sat Aug 01, 2020 7:25 pm Sure it's not a 1.3?
Yes, it is...
I reckon it's a leak somewhere, the rail depressurises and cranking doesn't prime it back up, but getting it running on the easy start spins it over fast enough to get the pressure up high enough to run properly on diesel.
I'd be checking all the hoses and the filter.
Scotsrich
Has thanked: 70 times
Been thanked: 549 times
Post by Scotsrich »
Is the battery okay?
It’s maybe not turning over fast enough to get the fuel pressure up.
Try jumping it from another battery.
As a free check it’s worth a go.
chillitt
Post by chillitt »
Lashed up a code reader, which says its the MAF sensor. So its probably the EGR...
chillitt
Post by chillitt »
Having pretty much given up on this one, (codes cleared now its relearnt the original fault) the owner has decided to take it away to get an MOT on it. Fat chance.. So this one has arrived. it has no common rail, no OBD port and no bloody codes to read. Apart from that, its horrible. MOT on Monday. here's hoping...
Has thanked: 836 times
Been thanked: 1239 times
Ooo, has it got manual Windows with razor sharp door pockets that cut your hands up when you get to a toll booth?
They're not 'manual' windows.
They're 'keep fit' windows.
chillitt
Post by chillitt »
Mussels wrote: Thu Sep 24, 2020 9:19 pm Ooo, has it got manual Windows with razor sharp door pockets that cut your hands up when you get to a toll booth?
Up until about 4 oclock it had a broken window winder where some joker had tried so hard to force it they bent both the arms.. Doesn't bode well...
rodbargee
Has thanked: 353 times
Been thanked: 980 times
Post by rodbargee »
fuel filter blocked a bit our vito was down on pressure in the fuel line and a new filter worked wonders
chillitt
Post by chillitt »
rodbargee wrote: Thu Sep 24, 2020 10:27 pm fuel filter blocked a bit our vito was down on pressure in the fuel line and a new filter worked wonders
I think both of these would benefit from a little TLC like that..
chillitt
Post by chillitt »
Speaking of TLC, I put two tyres on it today. Dont think this would have impressed the MOT chaps
chillitt
Post by chillitt »
Two little rust holes to sort, and a quick tinker with the back lights. thats very nearly an MOT pass! :D
Also, got the other one running this morning.
chillitt wrote: Mon Sep 28, 2020 2:12 pm Two little rust holes to sort, and a quick tinker with the back lights. thats very nearly an MOT pass! :D
Normally I'd say 'You mean you hope it's nearly an MOT pass' but I you are probably familiar with every MOT failure point. You should sell it as a service where people can bring their cars to you for a £5 once over to see if it's worth spending £50 on the real MOT.
