Cleaning ti headers
Demannu
Has thanked: 65 times
Been thanked: 1234 times
Cleaning ti headers
Post by Demannu »
My akra downpipes would make Weeksy cry. I've tried autosol, no joy. Not going to use harpic!
Anyone got some special goop (no, not Gwinny's foofoo juice) that will bring back that ti gleam.
Re: Cleaning ti headers
Why not the Harpic, the tinternets are awash with recommendations for it?
Demannu
Post by Demannu »
Harpic is a 9% solution of hydrochloric acid.
Anything more than 5% will start to eat your pipes, that's why it gives such spectacular results, it's dissolving the pipes.
Not likely to apply it every week, but have no desire to disolve parts of my bike.
Mix it 50/50 with council pop?
Has thanked: 2556 times
Been thanked: 4167 times
Buy a 5 litre container of brick cleaner (28% hydrochloric acid) and dilute it 1:5 (or 1:6 if you're nervous). 30 litres of sub-5% hydrochloric acid. You can clean a lot of metal with that...
Or do as Screwd suggests and buy a big bag of citric acid off ebay. Lots of uses.
Plus one on the "just water it down" approach. Might be obvious thing to say, but get some eye protection first!
I have 5kg tubs of both citric acid and bicarb (should probably keep em apart from each other)...they're great for all kinds of domestic jobs and way cheaper. Fancy cleaners pretty much just contain those sorts of things anyway, so just proceed straight to jail and do not collect £200 instead.
Pretty unusual to find something that one of those two can't deal with, perhaps in combination with my steam cleaner :lol:
Has thanked: 8035 times
Been thanked: 5693 times
Some folk out there recommend welder's pickling paste. It's a mix of hydrochloric and nitric acid! :wtf:
I found that there tends to be sort of glaze forms on the hotter end so a mild abrasive before applying any weak acid might help to keep the result looking more even (or mix the mild abrasive in with the weak acid to make a rubbing paste?). I know I ended up, after much effort, with a result that was still 'Meh. It'll do'. :D
Apparently there's some silicone spray you can apply after to keep things looking nicer longer. Can't see it working myself, or it'll make the job harder next time.
Mild abrasive is where the bicarb comes in handy.
Works terribly with citric acid though!
Trinity765
Has thanked: 3138 times
Been thanked: 3188 times
Post by Trinity765 »
Hold my beer.
I've found that wet and dry 600 grit sandpaper (used wet) is the best thing to start them off and then Autosol metal polish.
Has thanked: 7618 times
Count Steer wrote: Sat May 20, 2023 8:38 am Apparently there's some silicone spray you can apply after to keep things looking nicer longer. Can't see it working myself, or it'll make the job harder next time.
Hmmm sounds like BMW's supposedly corrosion resistant wheel paint. That peeled in patches and looked awful.
Yeah but the paint itself didn't corrode, it's fine. Just not on the wheel any more.
Horse wrote: Sat May 20, 2023 9:59 am
All I could find was 'design engineering silicone coating' which is supposed to be for high temp applications...but appears to be black or white. Looks like it's used before they put that 'orrible wrap fabric on exhausts (which is another way to hide unsightly headers).
Trinity765 wrote: Sat May 20, 2023 9:51 am Hold my beer.
If you use that welders pickling paste you may not have enough fingers left to hold the beer. :D
Demannu
Post by Demannu »
We're going with pink stuff.
Apparently its 60% quartz which is why its aces on metal!
There may be pictures!
BBB
Has thanked: 396 times
Been thanked: 118 times
Post by BBB »
I've got this
http://www.autosol.com/mobile/Product.aspx?id=37520
Works very well on stainless doesn't mention or not mention titanium.
BBB wrote: Sat May 20, 2023 8:51 pm I've got this
Apart from the bit where it does mention titanium :)
Bluing is primarily caused by getting hot though, so it's just gonna happen again.
Pgm
Has thanked: 6 times
Been thanked: 83 times
Post by Pgm »
Any update on this ?
Demannu
Post by Demannu »
Bit the bullet and used a 6% h2so4 mix. Rubbed it on, gave it 5 mins then rinsed. Super impressed with the results.
Has thanked: 2289 times
Been thanked: 2673 times
Wiping the pipes with vinegar removes bluing, no need for special goops
