Rider modes, do you use them?
- Has thanked: 15978 times
- Been thanked: 10257 times
I didn't bother with them on the mt09 and don't bother with them on the Hyper either. To me, unless you're in sport mode it just feels like there's something wrong with the bike as the other modes tend to reduce the power in one way or another. Should I appreciate them more, or do others feel the same?
- Been thanked: 7539 times
Re: Rider modes, do you use them?
Two up I use 'Road' for the softer throttle response, doesn't take the pillion by surprise. On my own I use 'Dynamic', unless I want to wheelie, then I use 'Enduro Pro'. I'd need the bumming hat before I ever considered 'Rain' mode.Taipan wrote: ↑Wed May 03, 2023 8:48 pm I didn't bother with them on the mt09 and don't bother with them on the Hyper either. To me, unless you're in sport mode it just feels like there's something wrong with the bike as the other modes tend to reduce the power in one way or another. Should I appreciate them more, or do others feel the same?
It's the only bike I've had with modes.
In my Ovlov I use 'Eco' all the time, which is why I averaged 54mpg on my commute home tonight in a 2 tonne car.
- Has thanked: 6382 times
- Been thanked: 4763 times
Had them on the K12 (but they were just suspension settings). The 'comfort' setting made me feel seasick, the second setting was OK but once it was put in 'Sport' on a Flash Tour it stayed there. It just felt like that was how the bike was supposed to be
The preload button was though, solo, 2-up, 2+luggage etc.
- Has thanked: 2947 times
- Been thanked: 1884 times
Rain mode on the ZH2 is a bit pointless, just twist the throttle less. Never put it in sport as I like the TC and anti wheelie where they are thank you very much!
- Has thanked: 10276 times
- Been thanked: 6891 times
In the GSXR1000 they were all too intrusive. Even the ABS sapped some braking power.
Turned it all off. But can't bypass ABS
- Has thanked: 65 times
- Been thanked: 1235 times
Pillion gets B mode and tc2
Solo gets std and tc1
Dont like the throttle response in A mode.
Perhaps I'm too used to carbs
- Has thanked: 9836 times
- Been thanked: 10149 times
Apart from non switchable ABS,I dunt have none,but I wanted to needlessly contribute anyway.
- wull
- Has thanked: 881 times
- Been thanked: 1551 times
On the beemer I have it in ride mode pro settings which means I can tailor it to how I want.
Usually it’s full power with anti wheelie switched off, engine brake is usually set to 2 which is the equivalent as what it is in the race setting, traction set to 1 but sometimes to 2 depending on temps etc. Abs is set for race as well but if you want you can switch it fully off.
Do you have to plug in a 'dongle' (hidden under the seat) to deactivate the ABS completely like on the GS, I assume it's a Euro standard thing that the user has to physically make a decision to do it, rather than it be a software option?wull wrote: ↑Wed May 03, 2023 9:21 pm On the beemer I have it in ride mode pro settings which means I can tailor it to how I want.
Usually it’s full power with anti wheelie switched off, engine brake is usually set to 2 which is the equivalent as what it is in the race setting. Abs is set for race as well but if you want you can switch it fully off.
- wull
No I can do it via the dash or the buttons on the switchgear.KungFooBob wrote: ↑Wed May 03, 2023 9:24 pmDo you have to plug in a 'dongle' (hidden under the seat) to deactivate the ABS completely like on the GS, I assume it's a Euro standard thing that the user has to physically make a decision to do it, rather than it be a software option?wull wrote: ↑Wed May 03, 2023 9:21 pm On the beemer I have it in ride mode pro settings which means I can tailor it to how I want.
I think, on my GS the only way to completely disable the ABS is in Enduro Pro mode, which is only available if you plug a hardware dongle in to the wiring loom (it's only a resistor).wull wrote: ↑Wed May 03, 2023 9:25 pmNo I can do it via the dash or the buttons on the switchgear.KungFooBob wrote: ↑Wed May 03, 2023 9:24 pmDo you have to plug in a 'dongle' (hidden under the seat) to deactivate the ABS completely like on the GS, I assume it's a Euro standard thing that the user has to physically make a decision to do it, rather than it be a software option?wull wrote: ↑Wed May 03, 2023 9:21 pm On the beemer I have it in ride mode pro settings which means I can tailor it to how I want.
With ABS being one of the requirements of the latest Euro standards I assumed it was a use this dongle and invalidate the Euro rating, etc...
- wull
The previous S1000RR bikes you had to have what was called the slick chip fitted which would give you slick mode and also the ability to switch abs and traction fully off. I had this on the gen 1.
On this bike it just has to be specced with the ride mode pro.
- Has thanked: 4364 times
- Been thanked: 2853 times
I don't have any modes as I am a riding god and use me ( highly experienced) right wrist as my modes init.
I have taken to leave TC in 2 as 3 it cuts in lots but in 2 it doesn't really come on and I'd rather have the safety net given the amount of gravel on most country roads nowadays. On WOT it does seem to stop the front coming up but doesn't seem to make much odds in forward motion so that'll do.
- dern
- Has thanked: 1017 times
- Been thanked: 1780 times
The only bike I have with modes is the 1190 adv s. It has sport, street and rain. I used to use rain when it's a bit slippery as the throttle response can be a bit aggressive but as I've got used to it I use it less and less. I've only had the front ABS cut in once during a training day with the IAM at North Weald when we were hard braking from 70mph to a stop. I only felt it cut in once for a fraction of a second even though the bike was out braking pretty much all the other bikes according to the instructors. I imagine that it would cut in in the rain if I was clumsy but it isn't intrusive. The rear abs has cut in a couple of times in the wet. The traction control has cut in a few times on wet roads. Overall the systems are really excellent and not at all intrusive.
- Trinity765
- Has thanked: 2442 times
- Been thanked: 2398 times
Sports mode all of the time apart from using Rain mode for mud or to get me to the petrol station as I'm running out of fuel. Road mode occasionally when I'm being really fickle and can't decide whether to use Sports or Rain.
I generally have the TC in 1 because the orange light that comes on when it's switched off annoys me, if it feels a bit slippery, I put it in 3
- gremlin
- Has thanked: 810 times
- Been thanked: 4806 times
I do for the first couple of weeks, more out of curiosity and novelty, to see how they differ, but then tend to stick it in Sports mode. If it's raining, I just ease of the throttle a bit. Ain't difficult.
I'm getting a bit pissed off with the Triumph Shift Assist, which negates the need for the clutch when going up and down. Being old and crusty, I'm used to shifting up with no clutch by applying a bit of pressure on the gear selector, then rolling off the throttle a wee bit. With TSA, as soon as there's even the slightest pressure, it shifts upbefore I've even had a chance to roll off even a bit. Makes changes jerky. I either turn it off or adapt. No decided yet.
I found that, when it was off I kept freaking out wondering what the light was. I'd then go 'Oh yeah TC light' and be happy before 15 mins later thinking 'What's that warning light'. Like a bloody goldfish. So I turned it back on.Le_Fromage_Grande wrote: ↑Thu May 04, 2023 11:42 am I generally have the TC in 1 because the orange light that comes on when it's switched off annoys me, if it feels a bit slippery, I put it in 3
Tried 1 first, then 2. Didn't seem to make any appreciable difference so went with the extra safety net.
The difference between 1 and 2 on mine is small, it'll wheelie about an inch (briefly) under hard acceleration in 1 and not at all in 2, with it off it's like riding a street fightered GSXR750, wheelies if you crack the throttle open in a low gear.Supermofo wrote: ↑Thu May 04, 2023 12:27 pmI found that, when it was off I kept freaking out wondering what the light was. I'd then go 'Oh yeah TC light' and be happy before 15 mins later thinking 'What's that warning light'. Like a bloody goldfish. So I turned it back on.Le_Fromage_Grande wrote: ↑Thu May 04, 2023 11:42 am I generally have the TC in 1 because the orange light that comes on when it's switched off annoys me, if it feels a bit slippery, I put it in 3
TC on mine is just too obtrusive.
On high setting it's like riding a 500. It's not dynamic. It seems preset.
Even on about 3 or 4 it cuts in when accelerating hard. Hot tyres on hot roads can handle all the power, thanks very much.
Never used it after first few rides.
My wrist is very experienced and better than most TC systems.
