Rust Curer
Ditchfinder
Has thanked: 622 times
Been thanked: 693 times
Rust Curer
Post by Ditchfinder »
After the Merc got written off I've replaced it with an older Volvo as a stop-gap until the 2nd hand market calms down a bit - hopefully!
Anyway the rear subframe and under the spare wheel well are a bit rusty - not crumbling but worried that left alone it wouldn't take long.
So my intention is to do something about it this spring once the roads have dried out a bit.
First thought is to use a rust curer of some kind and then apply something like lanoguard over the top of it to prevent it getting worse and then give it another coat of lanogaurd before winter sets in.
Does this sound sensible or should I be looking at something else? - It's only a £2.5k car so don't want to go mad and would prefer to DIY it if I can.
Also what's good for curing rust if I go down that route - I used jenolite back in the day but maybe there's something better these days.... :?:
roadster
Has thanked: 15 times
Been thanked: 147 times
Re: Rust Curer
Post by roadster »
I've used this
https://www.ebay.co.uk/itm/262315923139 ... media=COPY
It does work in the same way as Jenolite in creating a black coat of ferric oxide and also seems to be preventative to some extent.
Been thanked: 4125 times
Re: Rust Curer
Paint it with Hammerite, it already has the rust curing chemicals in it
Gregor
Has thanked: 1295 times
Been thanked: 872 times
Re: Rust Curer
Post by Gregor »
I used Hammerite kurust on the chassis of my old Fourtrak and the frames of my K100 and Tenere, works well about £15 250ml bottle but it spreads well .
Has thanked: 2921 times
Been thanked: 2061 times
Re: Rust Curer
I've used Hammerite Kurust converter and POR15 paint in the past, both worked okay.
Has thanked: 6382 times
Been thanked: 4771 times
Re: Rust Curer
I took a car with underbody rust to a local car maintenance place and they simply wire brushed the rusty bits and gave those areas a good going over with old engine oil. (Not enough to drip off or anything silly, just enough to collect a bit of road grot).
Has thanked: 1510 times
Been thanked: 1415 times
Re: Rust Curer
I just picked up some Rust Kutter that came in a squirty bottle.
Ant
Has thanked: 39 times
Been thanked: 227 times
Re: Rust Curer
Post by Ant »
Lanoguard as a general preventative measure.
If you've got anything which needs treating, use Bilt Hamber hydrate 80.
