Chains _ any better than others
- Has thanked: 1829 times
- Been thanked: 1469 times
I have just had a chain snap on me today - not something I really want to repeat TBH.
Combination of roots and mud pushed my gear cable end into the chain at the top jockey wheel - and seemed to prize the plates apart.
KMC / SRAM/ Shimano all much of a muchness?
If I ran a 10 speed chain on an 11 speed set up, is it less likely to snap?
Thoughts
Thoughts
- Has thanked: 5450 times
- Been thanked: 13085 times
Re: Chains _ any better than others
I'd have thought a 10sp on an 11sp would be likely to not work wellMr Moofo wrote: ↑Thu Mar 02, 2023 7:51 pm I have just had a chain snap on me today - not something I really want to repeat TBH.
Thoughts
reading about it, it seems to be plate dimension rather than thickness / strength.weeksy wrote: ↑Thu Mar 02, 2023 8:51 pmI'd have thought a 10sp on an 11sp would be likely to not work wellMr Moofo wrote: ↑Thu Mar 02, 2023 7:51 pm I have just had a chain snap on me today - not something I really want to repeat TBH.
Thoughts
I think it is a KMC that was on today ( will check - as I suspect it was a KMX lite - which was probably not a good choice.
- Has thanked: 2941 times
- Been thanked: 1882 times
Always use posher end SRAM chains as I never seem to have much luck with Shitmano, Wipperman or KMC. Just stay on top of chain wear with a checker.
See i'm different, i barely ever consider my chains, i run fairly low end chains and only use GT85, never use the chain checker, never have any issues.MingtheMerciless wrote: ↑Fri Mar 03, 2023 9:04 am Always use posher end SRAM chains as I never seem to have much luck with Shitmano, Wipperman or KMC. Just stay on top of chain wear with a checker.
Shimano have broken on me before - so I avoid them. So will look at the up-market SRAM ones - but I don't want lightweight
Maybe look an an e-bike chain if weight isn't a consideration.
That's one step to close to having an e-bikeMingtheMerciless wrote: ↑Fri Mar 03, 2023 9:24 amMaybe look an an e-bike chain if weight isn't a consideration.
