Seized Trolleyjack..
- Has thanked: 10266 times
- Been thanked: 6886 times
Bloody things jammed. Only had it 35 years
I can afford another one, but like tinkering sometimes.
Are there any serviceable parts?
All the lifting bits seem free. Just the pin that the handle pushes is seized.
Tips?
Tips?
Re: Seized Trolleyjack..
Don't leave it outside to turn into a rusty pile of scrap, I've got the same trolley jack and it still works fine and looks a lot better than that.
Last edited by Le_Fromage_Grande on Tue Jan 17, 2023 4:40 pm, edited 1 time in total.
- DefTrap
- Has thanked: 2261 times
- Been thanked: 2192 times
- Has thanked: 9829 times
- Been thanked: 10145 times
Give it a diesel bath.
- Has thanked: 484 times
- Been thanked: 1427 times
- Ditchfinder
- Has thanked: 621 times
- Been thanked: 692 times
I can't see any signs whatsoever of that pin being persuaded with a Birmingham screwdriver
It might need the big one but still, give it a tap
We always called it a Manchester ScrewdriverDitchfinder wrote: ↑Tue Jan 17, 2023 5:30 pm I can't see any signs whatsoever of that pin being persuaded with a Birmingham screwdriver
Got the special big one out. Yup. That moved the bugger
But it won't come back up
Undid the big nut and thread thing. Oil everywhere. Even with it in the vice, it's buggered.
Time for a new one. Always nice to buy new tools.
- Has thanked: 15957 times
- Been thanked: 10248 times
- Has thanked: 2405 times
- Been thanked: 3630 times
That's fucked, mate. I realise that this is tantamount to treason for a Yorkie, but you're gonna have to splash some cash for a new 'un...
Look up ac 50
-11 quid on Amazon , multiply uses on bikes and machines , little dab will do you last for ages but keep away from brakes and discs , apart from that always worth having some on shelf
Think it was designed for aircraft use, to prevent rusting in inclosed spaces as it creeps when applied , also good for sticky bolts ect ect lot of people used it on bikes over winter , but works on lawnmowers push bikes, off road bikes ect ect
Finally got me arse in gear and went to buy a new one.
Oh decisions. Trolley jack or bottle jack.
Bottle is lighter, smaller and cheaper. Are they any good ?
- ChrisW
- Has thanked: 2913 times
- Been thanked: 2053 times
Bottlejacks are fine, plus they can come in handy for jobs other than just lifting vehicles.
- Been thanked: 2617 times
Have you the clearance under your vehicle if it has a flat tyre for a bottle jack?
Thanks, I forgot to check, but the Mighty Duster does have mega ground clearance
- DefTrap
If I had the choice I'd have a trolley jack.
Mainly because bottle jacks seem to be used by
- people from the 1950s
- third world blaggers
