Guzzi With The Lot: 46Works Lemans 1000 Roadster
- Has thanked: 5453 times
- Been thanked: 13102 times
- Has thanked: 7821 times
- Been thanked: 2531 times
- Has thanked: 459 times
- Been thanked: 235 times
Re: Guzzi With The Lot: 46Works Lemans 1000 Roadster
I know it's all about the engine, but it looks out of place in that, which I guess is the point, but it looks too out of place.
- Has thanked: 2636 times
- Been thanked: 1523 times
The exhaust looks wrong, going under the sump. I know they wanted a 2 into 1, but like the originals, it would flow better alongside it, and give a lot more ground clearance.
At least it looks like it could be ridden.
- Has thanked: 15981 times
- Been thanked: 10258 times
Looks like they've put the engine in a 125 frame. Unbalanced look and it just doesn't fly for me.
- Has thanked: 4364 times
- Been thanked: 2853 times
Individual parts look stunning, but as a whole...dunno something doesn't look right.
- ChrisW
- Has thanked: 2919 times
- Been thanked: 2061 times
It doesn't seem to know if it's a scrambler or a café racer.
- Has thanked: 6382 times
- Been thanked: 4763 times
It's mostly OK but an awful lot of work has gone into getting that exhaust horribly, horribly wrong.
I quite like it, a longer seat so you could take a pillion and a different exhaust would improve it.
- Has thanked: 9836 times
- Been thanked: 10149 times
I'd like a pipe up each side. The droopy double pipe on one side offends my sense of the symmetrical.
I could chug about on that quite happily otherwise.
- Cousin Jack
- Has thanked: 2555 times
- Been thanked: 2290 times
Looks unfinished to me. Almost as though they got bored with it and threw the last bits on without any thought.
The Le Mans really is tiny. I stopped next to one at lights recently (it was immaculate) and my 600 dwarfed it.
- Has thanked: 10276 times
- Been thanked: 6891 times
- Has thanked: 1509 times
- Been thanked: 1415 times
- Has thanked: 6199 times
- Been thanked: 5090 times
Le Mans is tiny? Try a V50!The Spin Doctor wrote: ↑Thu Jan 12, 2023 5:49 pmThe Le Mans really is tiny. I stopped next to one at lights recently (it was immaculate) and my 600 dwarfed it.
The factory’s lead engineer, Lino Tonti, was in charge, and he essentially downsized the 850 everywhere while using the same 90-degree, wet-sump, overhead-valve V-twin, dry single-plate clutch, five-speed transmission, shaft drive and electric starting, although with a new electronic ignition system. The 57.3-inch wheelbase of the 850 Le Mans went down to 55 inches on the V50, the advertised dry weight from 475 pounds to 336 pounds, carburetor size (Dell’Ortos) from 36mm to 24mm.
- Has thanked: 2552 times
- Been thanked: 6260 times
All old bikes/cars are tiny aren't they?
Regarding the OP, we've managed to find a Guzzi I don't like which is saying something.
The V50 really is diddy. Sat on mine alongside a 50cc traily style moped, the kid on it looked down, saw the 'V50' badge, asked whether it was moped?
My 6'2" mate rode it, came back and said how comfy it was. I pointed out he was half sat on the pillion part of the seat!
Get a bigger pile?
