How much heat can powder coat take?
Bigjawa
Has thanked: 221 times
Been thanked: 878 times
Post by Bigjawa »
Looking to do something with the pipes on my gnarley sportster. The end cans are badly corroded as they're cheap aftermarket crap. I was wondering of I could get them, and the heat shields over the downpipes powder coated, I know there's different grades, just dont want it to melt, there's feck all baffles in the cans so they don't get really hot.
Re: How much heat can powder coat take?
In my experience not much, you're better off getting them Cerakoted, I know a place that can do it, but it's near Gt. Yarmouth
MyLittleStudPony
Has thanked: 616 times
Been thanked: 407 times
Post by MyLittleStudPony »
Stove enamel? Cheesy's Cerawotsit is probably better.
ogri
Has thanked: 1036 times
Been thanked: 224 times
Post by ogri »
Either bin the end cans and go raw or buy stainless/alloy new ones from any which/where on't internet ?
Ignorance is bliss
Has thanked: 6191 times
Been thanked: 5087 times
Whatever coating you use, how will you stop the current deterioration? Any condensation means they're likely to continue rotting from the inside. You might end up with just the plastic outer ;)
Bigjawa
Post by Bigjawa »
Horse wrote: Thu Dec 29, 2022 11:31 pm Whatever coating you use, how will you stop the current deterioration? Any condensation means they're likely to continue rotting from the inside. You might end up with just the plastic outer ;)
It's the cheap chrome that's pitted badly. the actual structure is quite thick.
Bigjawa wrote: Fri Dec 30, 2022 12:04 am
You're going to have trouble getting anything to stick to chrome, the best answer might be barbecue paint and accepting that you'll be redoing it regularly.
Has thanked: 599 times
Been thanked: 2443 times
Le_Fromage_Grande wrote: Fri Dec 30, 2022 10:53 am
Last I checked chrome ain't grinder proof.
That stuff holds up well on my smoker firebox, which gets a damn sight hotter than an end can, and lives outside 24/7
MrLongbeard wrote: Fri Dec 30, 2022 10:57 am
That's a lot of work, feck that.
Has thanked: 1507 times
Been thanked: 1412 times
Media blast & then ceramic coating like Jet-Hot etc
