Vice soft jaws, what's the best plan ?
Has thanked: 5449 times
Been thanked: 13084 times
I have a pair of these
https://www.ebay.co.uk/itm/Draper-Exper ... Swv-NWUzqi
But i now have a groove in them where when i've compressed the vice to hold something it's dug in too much and it's metal on metal. It also means i need to replace the part i've mullered at the time, it's probably only paint, but it's less than 100% and you know the rules in my game, things are 100% or they're not, simple as that.
So assuming you need to hold something and tighten a decent bit, say 50Nm what are you guys using/doing ? Wrapping it in rags ? plastic jaws ?
Has thanked: 599 times
Been thanked: 2428 times
Re: Vice soft jaws, what's the best plan ?
For 9 quid I'd be buying another pair
MrLongbeard wrote: Thu Jul 09, 2020 4:16 pm For 9 quid I'd be buying another pair
But i'm then still in the same position. Just with new jaws fucking up my part instead of used ones
Been thanked: 2612 times
Steel, plastic, aluminium, fibre, rubber or wood. Depends on the vice and what I'm clamping.
Also I've never thought about the exact clamping force, just tighten the vice to suit what's being clamped and what I intend to do the clamped thing.
What sort of thing are you putting in the vice and what are you doing to it?
weeksy wrote: Thu Jul 09, 2020 4:17 pm
Then I have misunderstood what yo're asking.
I thought you'd knackered your current soft jaws and were looking for a fix.
cheb wrote: Thu Jul 09, 2020 4:19 pm Steel, plastic, aluminium, fibre, rubber or wood. Depends on the vice and what I'm clamping.
it was one of these.
The bolt bottom right of the pic was incredibly tight and i had to really clamp it hard to stop it moving... Too tight obviously.
MrLongbeard wrote: Thu Jul 09, 2020 4:24 pm
I don't care about the jaws, i care about damaging other components next time.
For that I'd use plastic or wood. Old chopping boards are a good source for the former.
How about short lengths of old inner tube over the damaged jaws? It's in the nature of these things for the jaws to be damaged, hopefully instead of the clamped part. I realise my standards are lower than yours, and the value of the clamped thing will be less too.
Plenty of inner tubes, good plan.
It's not a question of value on this the part was £30, it's no biggy there, but I do want it to be 100%, that's the main priority.
When I take a pic next week of the damaged part I expect some abuse lol. But there's right, and not.
I try not to buy parts that cost more than 10% of the bike's original purchase price :mrgreen:
Damage or no, it'd go back on.
Ahh well, if nothing else you've reminded me I need some new soft jaws, god bless Amazon.
That'd be a couple of bits of old chopping board.
Can you get to the footpeg nut to loosen it when the hanger is still on the bike?
cheb wrote: Thu Jul 09, 2020 5:24 pm That'd be a couple of bits of old chopping board.
This time maybe, because I didn't do it up to 2000nm. Unlike Yamaha.
crust
Has thanked: 604 times
Been thanked: 515 times
Post by crust »
Did it have threadlock on it?
May be time to invest in a gas blow torch, a little heat very often makes things loosen easily.
I've got some solid nylon blocks and a pair of these for softer/rounder things.
https://www.ebay.co.uk/itm/2PCS-SET-4-5 ... ad92ac117d
crust wrote: Thu Jul 09, 2020 6:29 pm Did it have threadlock on it?
Will let you know, can't recall if I'm honest
Tricky
Has thanked: 2564 times
Been thanked: 2680 times
Post by Tricky »
weeksy wrote: Thu Jul 09, 2020 5:31 pm
I'll second that, heat is usually a great aid at times like these, albeit careful application in the case of lacquered things of course.
THese are the jaws I've always used, are harder than the other ones and pretty durable
https://www.amazon.co.uk/Eclipse-Tools- ... diy&sr=1-1
GuzziPaul
Has thanked: 59 times
Been thanked: 195 times
Post by GuzziPaul »
Can't find a picture but I would suggest two bits of wood shaped like a flat "M" or the bottom half of a "H". The two legs go either side of the movable bit of the vice with the centre section resting on it. This centre section extends up to level with the metal jaws. Although not made any yet as I did make these years ago.
Slip on and off in seconds but can fall of as well at inconvenient times.
iansoady
Been thanked: 169 times
Post by iansoady »
I have various vice clams:
- a set of Eclipse ones as shown above which have seen better days (I should really get some new ones);
- a pair made of flat wood about 6" x 4" with thin alloy on the back bent to fit around the jaws - used for woodwork;
- a pair made from folded soft aluminium which are best for holding things like screw threads;
- a pair made from thin lead sheet which are good for very delicate items.
With these I can generally find something to do the job.
Ian.
1952 Norton ES2
I've not tried lead, I don't know why, I just haven't
