LEAN AND GREEN: A SLICK SUZUKI GS500 FROM SLOVAKIA
- Has thanked: 5455 times
- Been thanked: 13102 times
- Has thanked: 2407 times
- Been thanked: 3637 times
Re: LEAN AND GREEN: A SLICK SUZUKI GS500 FROM SLOVAKIA
It has all the styling finesse of a park bench of the era.
- Has thanked: 6382 times
- Been thanked: 4764 times
It's ghastly.
(I don't hate it. But then, I don't have to own it. Often I think that even some of the bikes that have been beaten with the ugly stick might be fun to ride...but, that seat. )
- Has thanked: 9838 times
- Been thanked: 10149 times
If there wasn't a trend for bikes exactly like that and in exactly the same colours,then it probably would look tidy enough. Because everyone has jumped on the hipster bandwagon,it's now a poster boy for the generic. They've played the arse out of the game.
- Has thanked: 2636 times
- Been thanked: 1523 times
Tank's the right colour for one.mangocrazy wrote: ↑Thu Nov 24, 2022 9:59 am It has all the styling finesse of a park bench of the era.
Front wheel looks HUGE.
- Been thanked: 4125 times
Where's the battery?
Or the rectifier or ignition igniter box?
Last edited by Le_Fromage_Grande on Thu Nov 24, 2022 4:38 pm, edited 1 time in total.
- ChrisW
- Has thanked: 2919 times
- Been thanked: 2061 times
Under the seat apparently - little lithium unit.
What is it, 8 AA batteries wired in series, that bike doesn't run.
Hiding under the seat are a Motogadget mo.unit Blue controller and a tiny Lithium battery from Aliant.Le_Fromage_Grande wrote: ↑Thu Nov 24, 2022 4:39 pmWhat is it, 8 AA batteries wired in series, that bike doesn't run.
Where are the regulator / rectifier and cdi hidden away, neither are small and both get hot (and don't like being hot), the Motogadget doesn't appear to replace either, in fact reading their webpage it just appears to be an electronic relay box.Skub wrote: ↑Thu Nov 24, 2022 4:43 pmHiding under the seat are a Motogadget mo.unit Blue controller and a tiny Lithium battery from Aliant.Le_Fromage_Grande wrote: ↑Thu Nov 24, 2022 4:39 pmWhat is it, 8 AA batteries wired in series, that bike doesn't run.
Tis hipster magic. If you know,you know.Le_Fromage_Grande wrote: ↑Thu Nov 24, 2022 4:52 pmWhere are the regulator / rectifier and cdi hidden away, neither are small and both get hot (and don't like being hot), the Motogadget doesn't appear to replace either, in fact reading their webpage it just appears to be an electronic relay box.Skub wrote: ↑Thu Nov 24, 2022 4:43 pmHiding under the seat are a Motogadget mo.unit Blue controller and a tiny Lithium battery from Aliant.Le_Fromage_Grande wrote: ↑Thu Nov 24, 2022 4:39 pm
- Has thanked: 15982 times
- Been thanked: 10259 times
- Has thanked: 221 times
- Been thanked: 878 times
It's a 550, it won't need a big battery because they're a doddle to kick, just enough to fire the ignition. Does it even have a CDI as they were points ignition originally IIRC.
The wheels look huge because they are, 19inch front.
I like it. Few things i'd change, like the seat and i'd add side panels, but its a tidy, clean job.
- Has thanked: 7821 times
- Been thanked: 2531 times
I don't know why exactly, but the idea of an il4 having a kickstart just seems wrong somehow.
My Z1 came with a kickstart. I recall when manufacturers began dropping them in favour of electric starts,we were all wary of losing the foot back up if the starter lay down.Rockburner wrote: ↑Sun Nov 27, 2022 6:12 pm
How things change!
The first generation of electric starters were very marginal. They either didn't work or took so much power drag that if it didn't start first prod, it was back to the kickstart.
- Has thanked: 2552 times
- Been thanked: 6261 times
Starting handle FTW! They're just like swans.
It was a sign of manliness if you could start your bike by hand using the kickstart. Two strokes were cheating!
I remember starting my CD175 by hand on the kickstart. A Velocette Thruxton; not a chance...
