KTM dash misting
Asian Boss
Has thanked: 498 times
Been thanked: 650 times
KTM dash misting
Post by Asian Boss »
I little misting has appeared inside the dash on my 390 Adventure. I think it's only there when the weather's cold.
I checked and it's just outside warranty.
Worth doing something about or not worry about it and see what happens?
I don't ride in the rain and have only washed the bike once FWIW.
dern
Has thanked: 1017 times
Been thanked: 1782 times
Re: KTM dash misting
Post by dern »
That's not great. You could try and take it apart and seal it but I can't see that being successful unless a rubber compression seal has failed. I'd take the back off and chuck in a silica gel packet to see if that does the job.
Has thanked: 1829 times
Been thanked: 1469 times
I thought that was part of their character. A bit like Aprilia and Ducti, they all do that
Asian Boss
I think a little misting is regarded as normal on the headlight of my (2015) BMW car.
dern
Post by dern »
It'll cause corrosion in the long term if the problem persists.
Has thanked: 4365 times
Been thanked: 2853 times
I believe that's a very common issue so I'd at least try KTM first given it's only just out of warranty.
My 690 got a little misting once after I washed it and then started the bike after. But I didn't ride mine in rain or winter really so it might have been worse if I had.
Also take a look on the KTM forum, loads of posts about it that might give you some pointers.
