Meta alarm
wull
Has thanked: 881 times
Been thanked: 1552 times
Meta alarm
Post by wull »
The alarm on the wife’s bike is playing up, I’m fairly confident it’s dying batteries within the key fob so I’ve ordered some, failing that it’ll be a complete removal of the bastardin cuntin fuck!
Great when they work well, nightmare when they play up, had to replace the battery as well as that had died a death but that was my fault for not sticking the trickle charger on, I had for a while but unhooked it one day and forgot to hook it back up.
Still got some other jobs to do to the bike as well but this is priority for now.
ogri
Has thanked: 1038 times
Been thanked: 225 times
Re: Meta alarm
Post by ogri »
Bike alarms = spawn of satan :)
Ignorance is bliss
Buckaroo
Has thanked: 736 times
Been thanked: 719 times
Re: Meta alarm
Post by Buckaroo »
That's why I get Hawk alarms Demon or some such. Cheap, makes a lots of noise and is easy to install. You have a choice of really simple to full blown Thatcham level. Used them for years without any problems.
wull
Re: Meta alarm
Post by wull »
Batteries arrived so fired them in the fob and nothing, no difference. So the issue is the alarm itself.
I’ll strip it off the bike after work tomorrow and that will be that, should have done that years ago but it’s been fine until recently, there was tell tale signs that something was starting to go wrong, then it would maybe work every 10 times you pressed the button which made me believe it was more the fob itself but obviously not.
Been thanked: 7539 times
Re: Meta alarm
The alarm box itself will have a battery (for if the bikes main battery gets disconnected), might be worth looking if that can cause issues and if it's replaceable.
wull
Re: Meta alarm
Post by wull »
KungFooBob wrote: Sun Oct 23, 2022 7:00 pm The alarm box itself will have a battery (for if the bikes main battery gets disconnected), might be worth looking if that can cause issues and if it's replaceable.
I’ll have a read online see if it’s accessible, I know it has a tamper proof wiring block which you can get to with a drill and some perseverance. You can bridge the pins which bypasses the alarm but I’d just be as well removing it and returning it to how it was originally.
Battery is all connected up and the wiring is good so it should in theory work regardless of the back battery or whatever it has when battery is disconnected.
asmethurst99
Has thanked: 1043 times
Been thanked: 362 times
Re: Meta alarm
Post by asmethurst99 »
wull wrote: Sun Oct 23, 2022 6:55 pm Batteries arrived so fired them in the fob and nothing, no difference. So the issue is the alarm itself.
I’ve got a dead alarm on my Fireblade.I’ve. Ive no details with it and no fob etc but it’s not drawing the battery - one of the long term goals is to remove it but I’m even worse at electrics than I am at spannering.
Has thanked: 4365 times
Been thanked: 2853 times
Re: Meta alarm
Hate alarms, the only actual breakdown I've ever had was the immobiliser on the alarm on my KTM Duke II.
Has thanked: 2408 times
Been thanked: 3637 times
Re: Meta alarm
Alarms serve a dual no-purpose. Nobody takes a blind bit of notice of them when they do go off (other than annoyance) and they can and do fail at the worst possible time and immobilise the bike while doing so. I would never have one fitted to a bike and the only bike I bought (secondhand) with one fitted, I removed it PDQ.
Has thanked: 9839 times
Been thanked: 10150 times
Re: Meta alarm
What others have said,alarms are a ballache. Depending on area,some insurance companies make you fit one,but I'd never by choice.
Years ago I removed a Datatool from a Fireblade,it was a slow painstaking process,one wire at a time.
Re: Meta alarm
Just to counter everyone else's point.
I had a Meta fitted to my new R6 in 1999. For the three years I had the bike it worked perfectly and never let me down over 21,000 miles.
My GS has the factory alarm fitted, it's all integrated and works perfectly, the siren is a bit quiet tho'
Has thanked: 600 times
Been thanked: 2451 times
Re: Meta alarm
Swing's n roundabouts.
The Datatool on my Triumph was a steaming pile of poo, but easy to ditch as all you need is a jumper to plug into the loom.
Whatever is fitted to the Harley has given me no problems at all, except for me forgetting the have the fob in my pocket when moving it around the garage.
I've got one of these in the garage, keep meaning to find something to fit it to
wull
Re: Meta alarm
Post by wull »
I’ve been off work today because the wee man is poorly so went out and made a start on the wiring whilst he was having a nap.
That’s it done, not completely done as in I still have to tidy it all up but I exposed all the wiring, sussed out what was needed and connected up the original loom quickly just to see if it’ll work, and it works fine.
Job this evening when the wife gets home is remove the wires which have tapped into the indicator and lights, then do the important ones properly with the solder and that.
A_morti
Has thanked: 310 times
Been thanked: 568 times
Re: Meta alarm
Post by A_morti »
Now you'll restart the debate of whether soldering the wires is doing it "properly" or not.
Looking at Alloa on the map and seeing it's on the seaside, then considering some of these wires interrupt the bike's start & run circuits, I'd want something completely waterproof to also keep out sea air that will eventually turn the soldered wires green. Even more so in case they tap into anything with a 5v signal on it.
https://www.amazon.co.uk/Connectors-Wat ... 07GDHXN21
Either way, congrats on the exorcism :)
wull
Re: Meta alarm
Post by wull »
A_morti wrote: Mon Oct 24, 2022 3:24 pm Now you'll restart the debate of whether soldering the wires is doing it "properly" or not.
I have various methods plus the paste to keep it nice and sealed, I also have them soldering sleeve thingy mabobs, I forget what they’re called. Either way it’ll be better than it was with the alarm fitted.
Has thanked: 7821 times
Been thanked: 2531 times
Re: Meta alarm
MrLongbeard wrote: Mon Oct 24, 2022 12:47 pm Swing's n roundabouts.
The front door?
wull
Re: Meta alarm
Post by wull »
Heap of shite
wull
Re: Meta alarm
Post by wull »
That’s better.
Has thanked: 6382 times
Been thanked: 4764 times
Re: Meta alarm
wull wrote: Mon Oct 24, 2022 6:36 pm Heap of shite
You need to put a stake through its heart otherwise it'll strangle you in your sleep. :(
Q? Where did you get those interlocking tiles? If they're a reasonable price I might do the garage floor. (Would have gone with self-levelling sealant but completely emptying it now would be :( ).
wull
Re: Meta alarm
Post by wull »
From Halfords, I think they’re up to £16 for a pack of 6 now. They were £10 when I first started buying them.
